Question about Emerson LC195EMX 19 in. TV
When changing channels the screen changes different colors the entire screen that is red,green,yello,white...ect...
    Genius:
  • 1,112 Answers
Hi:
This seems to be a some type of connection problem either on one of the boards such as the main board or analog board, I would check for bad solder connections around the board that the tuner is located. Also check you video connections going into the television.
Posted on May 14, 2010
Screen changes color from white - black - red - green - blue. The entire screen changes on it own. Nothing else on the screen.
push the vol up and then the vol down on the side of the tv or ch up then ch down, the set is stuck in a factory mode, this will clear it.
Aug 19, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
How to hook up wire to vcr
take the yellow rca cable and push it into you video out, the the other colors red and white rca's on the left and right channel audio out, really easy, then plug in to the pc via usb, and connect, if you dont get it right email me, bertus_kriel@yahoo.com then take me a photo of the back of the vcr then i will show you, how
Nov 02, 2009 | KWorld DVD MAKER USB 2.0 (660448660114)
I have power to my ps3 but no pictu on the tv.
Also, if it was previously plugged in to HD, it might need to be switched back to SD cable. To do this switch your ps3 off, then press and hold the power button when you turn it on. It will beep once when you turn it on, then beep again after a few seconds. Once it's beeped the second time the display settings will be reset and hopefully it will show up on the screen.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
I am a surgeon when I take pictures of muscle or bloody objects the red color seems to melt and the red is overly saturated and all sharpness and definition to the photo is lost usually taken with a...
The Fuji S2 sensor is noted for this red sensitivity. Here's a few different approaches to getting the shot with the S2, all of which require some experimentation.
1. Set the "Color" and "Tone" Function options to "ORG". Underexpose the shot. Progressively change the exposure compensation downward until when checking the histogram, the red channel does not show saturation at the high end. Advantages: this is the simplest approach to getting the picture. Disadvantages: the S2 already had a fairly limited dynamic range, and this will make things worse for the parts of the photo that are not red. For the surgical setting and use of a ringflash, this may not be much of a disadvantage, since a lot of the stuff of interest will be red, and ringflash illumination generally is of lower contrast than directional lighting.
2. Set the "Color" and "Tone" Function options to "ORG". Use a custom white balance. The idea here is to have the camera adjust the red channel sensitivity itself, and leave the blue and green channels alone. To do this, start with several sheets of white paper and a red or pink marker or highlighter. Scribble with the marker across a sheet, then use that to set a custom white balance. Take a test shot of the red stuff that has been problematic, and see whether the histogram for the red channel shows that there is no saturation at the high end. Repeat this with progressively more red or pink on each sheet used to set the custom white balance until you find the custom white balance that takes enough of the edge off the red channel response. Alternative: I just tried out making a gradient across an 8.5x11" sheet of paper going from white to about 30% red saturation. I can set more or less red adjustment in a custom white balance just by pointing the camera at different parts of the page. This seems to work OK for me. Advantage: can allow the full dynamic range of the sensor to be used. Disadvantages: the experimentation period is likely to take a while to get the best results, and the final images are unlikely to look completely natural.
3. Set the "Color" Function option to "B/W". Use a green or cyan filter on the lens to cut the amount that the red color channel contributes to the final image. Advantages: this is fairly simple as an approach. A similar post-processing technique can be applied to the photos that you already have, by nulling out the red channel contribution and desaturating the blue and green channels to produce a grayscale image. Disadvantages: you lose the color information entirely. Since much of what you want information about is colored red anyway, the organs are likely to appear quite dark when only taking the blue and green channel contributions to the image.
Feb 26, 2009 | Fuji FinePix S2 Pro Digital Camera
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Hooking up the dvd player to the new tv
No you don't need them. The red, blue, green wires are component cables for HD.
Jan 26, 2008 | GPX D1816 DVD Player
Emerson LC195EMX 19 in. TV Logo
56 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
