Question about Philips Senseo HD-7810 Coffee Maker
Even after flushing my senseo won't start...
I just got my senseo coffee maker but I can't make it work. It will turn on but (even after flushing it a few times now) the blincking will not stop and I can't make any coffee...
  • 5 more comments
  • Hikr Apr 05, 2008
    We ahve the exact same problem as BeateVa. Tried flushing 4 times. Won't work
  • EvilTwinPsu Apr 24, 2008
    i have the same problem. Wont stop blinking
  • Kellaq May 11, 2008
    I have got the same problem, I read the instruction "important", which attached on the back of the machine, and fill in a liter of water(less than maximum), put a mag in front, and turn the machine on, it just do not stop blinking.
  • jacklam May 11, 2008
    I have problem to use it for the first time. after turn it on, it just keep making loud noise, nothing happens.
  • Anonymous Jul 23, 2008
    I have flushed it many times and it just does nothing! I think I may just pitch it and go back to my regular coffee maker. I complained to the maker and I have not heard anything from them! Great Customer Service guys!!
  • Anonymous Jul 29, 2008
    It keeps blinking and will not make coffee.
  • ropesend Oct 05, 2008
    Same problem. However, I can wiggle the dispenser back and forth a little so that it makes the warming sounds and will give me one cup and then I have to hold it again and wait for the blinking to stop and push the button and out she comes. It is so inconvenient I am ready to throw it out and NEVER buy another Senseo.
  • 5 Answers
SOURCE: stuck senseo maker
Your machine has been locked because there is too much pressure inside the machine. Unplug it for about 24 hours and leave it with the lever up. After that it should come open. Carefully clean out the tiny nozzles to make sure there isn't any loose coffee hanging out in there. This happens if you make your own pods. Just be grateful that it didn't explode all over your kitchen!
Posted on Mar 05, 2008
  • 5 Answers
SOURCE: Senseo coffee maker
There isn't a way to adjust it. The senseo is calibrated to make either a 4oz or 8oz cup. Unfortunately, we are so used to buying mugs at the store that are MUCH bigger than this!
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Posted on Jan 06, 2009
  • 17 Answers
SOURCE: Senseo machine has started producing very weak coffee
try descaling the machine first, build up may be causing problems. its in the direction book on the senseo site.
If that doesn't work
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Posted on Feb 23, 2009
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
Coffee is watery. Not sure if its the maker or the new senseo pods. I recently used white vinegar solution to descale and since the coffee is terrible ... very watery. Is it because of the descaling,...
Hi. Who says to use vinegar. I wouldn't use that. Sounds like your pump is not pumping at right pressure. Vinegar can make the lime/calcium build up, break up into too large of pieces. which can block the pump. Descale solution breaks these deposits up. allowing it to be flushed from the system. Dazza REPAIRER
Sep 23, 2011 | Philips Senseo HD7832 Coffee Maker
run vinegar thru it... go buy a gallon of it... and run a couple cups thru it...
then use filtered water or distilled water to flush that vinegar out...
then go buy yourself a Brita Pitcher... and use that... cheaper then using distilled water...
May 06, 2010 | Philips Senseo HD-7810 Coffee Maker
Hi, while making coffee, I forgot to put a cup in the machine and the coffee flowed over. I cleaned it up, but now the senseo won't start. No lights come on. I wanted to see if maybe inside it got wet, but...
Usually, overflowing won't harm the machine in any way; it's built for that. Even if liquid somehow would get into the device, it will remain fully functional in 99% of the cases once it's fully dried again.
Opening the bottom will void any warranty you may still have. If a Senseo doesn't do anything please make sure it's plugged into a working wall socket (check the wall socket using another applicance). Wall socket OK, but still no joy? The internal fuse may have blown - but it's recommended you leave repairs to a qualified mechanic.
Nov 04, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
Aug 26, 2009 | Philips Senseo HD7832 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo won't fill itself on initial flush
Sounds like resevoir was not seated properly or something is in the resevoir. try pushing the pin on the bottom of the resevoir, do it over the sink, and see if water comes out. if tht works then its internal to the machine. Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Oct 21, 2008 | Philips Senseo HD-7810 Coffee Maker
Pump doesn't pump
Yes, it is called descaling. Use a descaling solution, or vinegar and water, and follow the procedure for flushing your machine. After that, re flush it with plain water- nothing worse than vinegary coffee!
Sep 17, 2007 | Philips Senseo HD-7810 Coffee Maker
Senseo making to much coffee
Try flushing the machine by filling the water tank with water and then pressing both the one cup and the two cup buttons at the same time (make sure to put a big enough bowl under the spout). If this doesn't work, give Senseo a call: 1-866-4SENSEO. They should be able to help! Good luck!
Aug 15, 2007 | Philips HD-7810 Espresso Machine
Philips Senseo HD-7810 Coffee Maker Logo
Top Philips Coffee Makers & Espresso Machines Experts
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
