Question about Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat
Float does not rise all the way and toilet runs. Can't figure out how to open one piece assembly
  • Randy Marshall May 29, 2010
    http://www.inspectapedia.com/plumbing/To... Check this web site out for maybe some info for you to help. Do you know if the fill valve is a fluid master valve, writing maybe on top of it?
    Is it a fluidmaster ? If it is go to following website for some information for you.http://www.fluidmaster.com/index.asp?bhc...
5 Suggested Answers
  • 659 Answers
SOURCE: IS THE FLOAT ASSEMBLY (Mfg. p/n 08204) available
http://www.thetford.com/HOME/CUSTOMERSUPPORT/ProductManuals/tabid/265/Default.aspx
Follow the link above. This is where you will find the manuals to your RV toilet. You will probably find everything you need here are at least a phone number to speak to a real person. Good luck and I hope I was able to answer your question.
Posted on Mar 20, 2009
  • 16 Answers
SOURCE: Toilet continues to run. THe plastic float cup
The adjustment is inside. It just needs to be adjusted.
Posted on Jul 10, 2009
bearsfan7538
  • 119 Answers
SOURCE: How do you adjust the float valve in a kohler one
You will see a metal clip on the rod that connects to the square float lightly compress the clip for more water in tank lower clip for less raise the clip if this does not work you need to service the valve
Posted on Nov 15, 2009
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
Why wont my toilet shut off after flushing?
Sounds like your float may need to be repositioned. Try bending the rod that supports the float so the float is further down in the tank. If this doesn't work then you need to buy a replacement kit for the shut off assembly. It is all one piece and includes the float and is easy to replace.
Aug 17, 2014 | Mansfield Plumbing Products Home
Toilet will not stop running
That old fashioned ball float has to rise sufficiently to turn off the fill valve but the float may be leaky and unable to rise enough. Also, the ball float may be rubbing against the rear wall of the tank and not rising completely. Check the flapper at the bottom of the tank. It may not be seating properly. Flappers do not last very long regardless of design
Apr 12, 2013 | Home
Water keeps running continually I lowered water level and it still runs
Two possibilities. the flapper may not be seating correctly and not letting the water fill the tank high enough for the float to shut off the water. In this case replace flapper as they wear with time and chemicals and the rubber loses its elasticity and becomes very hard or brittle. Second if this does not solve problem, Replace water fill valve, it may have a grain of sand or spec of dirt inside it not letting it shut off completely when the float rises.
Aug 25, 2011 | Danze DC023230 Cirtangular Two Piece...
Water level is set too high and runs over the overflow. how can i adjust the water level in the tank?
Inside the tank, on a lever arm there should be a cylindrical float that rises and lowers with the water level. Attached to the float is a float rod with a clip that can slide up and down the rod. You can adjust the water level by sliding the clip down to reduce the amount of water entering the tank. As the water fills the tank, the float rises, pushing up the float rod, which in turn pushes up the level that controls the valve allowing water to enter the toilet.
Jul 29, 2011 | Kohler K-3515-0 Memoirs Comfort Height...
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
My toilet handel is broke.how ican install
Remove the water cover lid then remove the chain connector at the handle looks like a diaper pin then unscrew the nut holding the handle in place and feed the handle assembly threw the nut and buy new handle assembly and replace. IF it's just the chain is broke replace the chain they are sold separately at any hardware store. IF it's the valve you can replace it as well by shutting off the toilet water valve, next disconnect the hose and go buy a float assembly that is similar. Adjust the new float assembly to be the same length as the old one then install gasket on the float and put in the hole for the float, install second gasket on the float on the outside and then install the nut and install the hose. Before you tighten the nut on the float make sure the float valve lines up with the handle and the float then tighten down hook up new chain and tighten the water hose, tighten the nut on the float and open the water valve. Watch the water level fill up if it looks like it's going to run over you will have to adjust the float so that it does not run into the throat of the toilet.
Dec 10, 2009 | Mansfield Plumbing Products Mansfield...
The toilet has water running continuously from the tank but not to the stool
bad shut off float pull the float up manually does that shut it off if so adjust float to go off at a lower water level. If it doesnt replace it. The float is attached to a water shut off valve as it rises to a certain point which you set, when it reaches that water level it shuts off the water.
Oct 18, 2009 | Pegasus Technologies Elongated 2 Piece...
Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
Nov 28, 2008 | Home
Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat Logo
611 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
