I built a new computer and when trying to load windows, it gets to the point where it actually starts windows to finish the setup and then after a minute or two the computer just shuts off completely (like the power got cut). It will stay on in BIOS and in Windows safe mode. The problem only occurs when Windows is started normally. System specs: MSI P55-GD55 mobo Intel core i5-750 CPU g.skill 4GB(2x2GB) DDR3 1333 (PC3 10666) gigabyte Radeon HD 4350 512MB 64-bit GDDR2 OCZ StealthXStream 700W PSU Western Digital Caviar Blue 160GB 7200RPM hard drive
  • saxman487 May 15, 2010
    I've tried installing Vista and Windows 7. Both end up with the same problem.
  • 11,800 Answers
Bad install, most likely related to the default drivers (since it can run in Safe Mode) - either something was corrupted during the process or the disk itself is busted. Try installing with another disk.
Posted on May 14, 2010
  • Azrael SRL May 15, 2010
    Check that in the BIOS every component is correctly identified and configure. Test the pc for a hardware fault by booting from a Linux Live-CD likehttp://pclinuxos.com/  While in there test the memory also using memtest.
I accidently deleted my scsi driver on my OLD but love-able xp system. Can you tell me how to get a new one and install?
try system restore. it will sent the system to an early time before you deleted the drivers.
click windows logo>>search bar type>> system restore>>>
then select system restore,then when is opened.. select older/more
system restore check point..>>> select the check point before the incident.....
this will leave your pc in the state it actually was before you erased the drivers... let the computer finish the restore,it will reboot by itself. good luck
Feb 17, 2015 | Computers & Internet
Tip
How to Send a Fax with Microsoft Windows 7 Note for you to use the built in...
Note for you to use the built in "Windows Fax and Scan" option to send faxes you will need to have a dial-up modem installed in your computer.
1. To access the software click the "Start" button and in the "Search Programs and Files" box type "Windows Fax and Scan".
2. Next click on "Windows Fax and Scan".
***Note Will Finish The Setup Process When I Get To My Computer With A Modem In It***
on Jul 28, 2010 | Computers & Internet
T42 gets message"NTLDR" not available. Tried to
Don't try loading windows with out fixing the NTLDR...Try this simple steps in recovery console,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
  • Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Note:
    Do not use the repair option in the recovery console.
    Or, if you can get into XP, even safe mode, you can arrange to bypass the
    password by the following registry change:
    Click on Start then click run and type Regedit. Navigate to the key mentioned below,
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Setup\RecoveryConsole
    Set the DWORD Security Level value to 1
Hope this helps
Dec 27, 2010 | IBM ThinkPad T42 Notebook
Turn on the computer get a blue screen says unmountable boot volume wont let me start in safe mode or any mode
Something has corrupted the boot information on your hard drive so Windows can't load. This might mean the hard drive itself has failed. but it might also just be a software problem. If you can borrow a Windows installation CD, you can try repairing the software. You didn't give your operating system, so I'm assuming you have XP.
On every Windows XP CD (it doesn't matter which version, Home or Professional, full or upgrade), there is a very handy tool called the Windows Recovery Console. Here is how to try repairing your Windows installation using it:
  1. Put your XP install CD in the drive and restart the computer so it boots from the CD. If your computer isn't set to boot from the CD first, you will need to change the boot order. Watch the screen when the computer starts up. On some systems you can reach a boot menu by pressing the specified key, or you might need to change the boot order by going into BIOS setup. Again, the key to press will be given at startup.
  2. After some time loading files from the CD, the setup program will show a screen saying "Welcome to Setup". Press R to start the Recovery Console.
  3. The Recovery Console will list Windows installations it finds and ask which you want to log on to. Usually there is only one installation, so press 1, then ENTER. (Note: At this point, if there are no Windows installations listed or you've gotten other error messages, either your hard drive is bad or your Windows installation has been wiped out, possibly due to a virus. All you can do is try a fresh, full reinstallation of Windows.)
  4. You'll be asked for the Administrator password. Unless you changed it when Windows was working, the password will be blank, so press ENTER. You will see a C:\WINDOWS> prompt.
  5. Enter the command CHKDSK /P and press ENTER. (You don't need to enter the command in capitals, I just did that for readability.)
  6. Let the command do its work. You'll probably see several messages about recovering or repairing errors. When it's finished, the Windows prompt will return.
  7. Type EXIT and press ENTER. Your computer will restart.
  8. Remove the CD so Windows will try starting from the hard drive normally. If the repair was successful, whatever was corrupted will be fixed and Windows will start up properly.
If the repair doesn't work, again it's either hardware (you need a new hard drive, or in some rare cases a new system board) or the Windows software was too damaged for repair and needs to be completely reinstalled.
Good luck with your repair, and thanks for using Fixya!
Oct 09, 2010 | Computers & Internet
Recovery
Here are the complete instructions to do the Recovery in the Computer.
Note: The Recovery will erase all the data in the computer and restore to the factory defaults.
The VGN-FE770G computer has a Recovery Partition built in it. You can use the Recovery Partition to do the System Recovery. You can access the Recovery Partition using the "VAIO Recvery Wizard" software installed in the Computer.
  1. On the taskbar, click the Start button, point to All Programs , point to VAIO Recovery, then click the VAIO Recovery icon.
  2. In the VAIO Recovery window, click to select the "Restore C: Drive" option to do the System Recovery.
  3. Then, in the Restore C: Drive window, click to select the I understand box.
  4. After that, click the Next button.
  5. After the bundled applications are installed, under Restore C: Drive (Step 4 of 4) , click the Finish button.
  6. The computer will restart and the operating system setup wizard will begin.
  7. Please follow the on-screen instructions to complete the setup wizard.
All the best...
Sep 12, 2010 | Sony VAIO VGN-FE770G Notebook
Gateway laptop modle mx8711 windows failed to load
Try to start in safe mode and then when it finished loading shut it down again. Boot again it should boot to windows if it not, maybe a corrupted files or some files are missing.
Apr 01, 2009 | Microsoft Windows? Vista Home Premium...
Hello, i have a Fujitsu Siemens Celsius R610 PC. I wiped the hard drive and trying to load a fresh MS Windows XP Prof on but it won't let me. Its saying it can't load or see the HD. any thoughts.
In order to fully install windows you need to have the driver loaded for your SCSI controller built into the mother board. Here: http://support.fujitsu-siemens.com/com/support/downloads.html is the website to get the SCSI drivers. Just make a floppy disk with them and when you load windows setup from the disk when it asks you to press F6 to install third party drivers do so. Then just point to the disk and load them up. When windows finishes loading the rest of the drivers and starts the setup process your hard disks should now be accessible.
Jan 10, 2009 | Fujitsu Siemens Celsius R610 PC Desktop
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
I just set up a new Windows Vista computer. Last night, I had no problem loading programs, but today it won't let me load any programs. I inserted a new Microsoft Office disc and nothing happened. I...
hi,
you can try restoring ur system to time when it was working fine, and please try it in safe mode
  1. To be safe, backup any important files before restoring from a restore point.
  2. Close any software windows that are open.
  3. Click Start c00847244.gif , All Programs , Accessories , System Tools , and then System Restore . The "Restore system files and settings" window opens.
  4. Select Choose a different restore point , and click Next .
  5. Select a date and time from the list of available restore points and click Next . All affected system files will be added, removed, or changed to the same versions that were in the computer's system file configuration on the selected date.
  6. Click Finish in the "Confirm your restore point" window.
  7. Click Yes in the confirmation message that opens.
  8. The computer should shut down and turn back on automatically after the restoration completes.
May 20, 2008 | HP Computers & Internet
Reloading windows 98 on a Panasonic Toughbook CF37
http://support.microsoft.com/kb/262381/en-us
Restart in Safe Mode and Use Msconfig.exe loadTOCNode(2, 'resolution'); Restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then choose Safe Mode from the Startup menu. For additional information about Windows 98 startup, click the article number below to view the article in the Microsoft Knowledge Base: 178548 (http://support.microsoft.com/kb/178548/EN-US/) No 'Starting Windows 98' Message at Startup After your computer restarts in Safe mode, use the System Configuration Utility tool (Msconfig.exe) to minimize conflicts that may prevent your computer from finishing Setup.
To start and use the System Information tool: 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Information. 2. On the Tools menu, click System Configuration Utility. 3. On the General tab, click Selective Startup, and then click to clear the following check boxes: • Process Config.sys FileProcess Autoexec.bat FileProcess Winstart.bat File (if available) • Process System.ini FileProcess Win.ini FileLoad Startup Group Items
Dec 05, 2007 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
