Question about Maytag MSD2756G Side by Side Refrigerator
Ice Maker Water Valve needs replacement
Hollow ice, incomplete ice dumping
Need valve part number to order replacement
    President:
  • 1,796 Answers
Hi!!
With the make, model and serial # of your unit, You can get replacement parts at any authorized distribuitor or places like Johnstone Supply where OEM parts are less expensive.
Just to play it safe, take the old part with you.
Don't forget to rate this post. Good Luck.
Posted on May 14, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
New refrigerator. Just stopped making ice, Still gives cold water.
Your model is listed as an oven when looked up. You may want to send the correct model number and that will speed things up. Samsung prefix is RS2 not RF2 I will give you the parts for the RS265AA and most likely the water control valve will be the problem Don't worry too much about the model number but before you order or buy one you will need the correct number. Fill tray with tap water and try first. If ice dumps then the water valve if not working then the ice maker if it remains full of ice and does not dump then that is the problem. Here is a photo of the Da74-40149D Water Control Valve You can find it here=> Appliance Parts Southeast or Appliance Repair Point and Click
If it should be your ice maker the part number is=> DA97-0258C
1bc7c93.jpg Ice maker 485efd2.jpg You can find me here at Fixya or=> Here or here=> Sea Breeze Appliance Parts and Technical Services if you need answers let me know! Thank You, Sea Breeze
Dec 13, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ice maker is not dumping solid ice. Half moons are still unfrozen in the middle
You need to replace the water inlet valve behind the refrig where the wall water line connects to on the refrig . This is caused by not enough water going into icemaker . Called " hollow cubes " condition .
Oct 15, 2009 | Kenmore Refrigerators
Icemaker stopped making ice.
If not filling with water the water control valve is most likely the problem. Pour tap water into tray let freeze and if it cycles and dumps the ice then the water control valve is the problem. If the ice maker does nothing trying this the the ice maker is most likely the problem, I need your model number to confirm which type ice maker you have because some do not have replacement parts. The model number of your Whirlpool Refrigerator, Thanks Sea Breeze
Oct 02, 2009 | Whirlpool Refrigerators
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Ice maker is inop. There is water to the door dispenser but not to the ice maker.
It’s more likely that your 61005626 Dual Outlet water control valve has become defective on the side that turns the water on for the ice maker. Sometimes the ice maker is the reason for this problem. The ice maker has a temperature thermostat that sometimes goes bad and will not tell the water control valve to come on after dumping the ice and the end of its cycle. The part number for the temperature thermostat is 627985 you can test the ice maker to see if the thermostat is bad by filling it with tap water and allowing the water to freeze. If after freezing the ice maker cycles and dumps the ice but does not refill with water then the water control valve needs to be replaced. Try that test and let me know what you find, Thanks, Sea Breeze
Sep 07, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker overfilling
When your ice maker rolls around in the harvest mode, near the end it comes into contact with a copper plate mounted on the inside of the main drive wheel so that the water valve can fill the ice mold for 7.5 secs. This tiny piece of copper gets all burnt to hell from the arcing and can cause everythang from overfill to no fill.Remove the main drive gear and clean that copper. Or just bust a move and buy another IM.
Jan 02, 2009 | Maytag M27I Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
75 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
