Question about Nokia N900 Smartphone
Nokia N900 not turning on or charging - Nokia N900 Smartphone
Not turning on. red notification light showing
Posted on Jan 05, 2011
    New Friend:
I have had the same issue. It seems to me that the issue is with the battery having run too low - the n900 seems to want a certain level of juice before it can start charging in earnest.
Whenever I would plug the phone in via the USB cable, I would get a flashing red light and no charging. I noticed that when using the AC charger, the light blinked yellow. I assumed that this meant SOME charging was taking place, but only intermittently before it would return to the blinking red.
I assumed the AC charger gave it a little juice whenever it was plugged in, which dissipated as soon as the n900 tried to engage whatever charging mechanism it has, returning it to the blinking red state.
I resolved the issue in the following way:
Using the AC charger, I plugged the microUSB cable into the port and left it plugged in for only about a second - just long enough for the yellow light to come on. I would then immediately unplug the cable. Then, I plugged it back in - once again, for only about a second. I repeated this process a few times, and then plugged the cable in and left it in. I noticed that this time, some screen almost came up before it returned to the red low-battery blinking state. I saw that progress was made, so I returned to plugging the AC charger in and out (bear in mind, you must plug/unplug the microUSB end, NOT the AC-prong end, as it seems that the AC-DC adapter needs that one second to energize its internal electronics, and will NOT put out as much juice as the n900 needs in that one second) for about 5 minutes. It felt very dumb, but it upon plugging the cable in for the last time, the battery seemed to have enough charge to enter a charging state.
The n900 seemed to forget what country I lived in after this process, but that was easy enough to input.
I had tried to reproduce the problem, and did so successfully. This time, though, the battery was so dead that the yellow light would not come on - only the red. After repeatedly plugging the microUSB cable in and out every second or so (this was the test where I found you should not plug/unplug the AC-DC adapter itself, but only the cable), it eventually got to a state where it could fully charge.
Hope this helped. You may toss me a line if this helped you or if you have other questions about my experience: freddfu@yahoo.com
Posted on Sep 27, 2013
  • fred Oct 09, 2013
    Update: If the battery is discharged fully, the above will not help at all. In this case, you need to charge up the battery manually. You can try charging it in another N900, or a N810 http://www.maemonokian900.com/maemo-news... or get creative like I did. I used a battery holder lying around to stick some AA batteries together, and fiddled with some of the batteries to get around 5V. I simply jump-started the BL-5J by connecting the +/- terminals of the battery pack to the +/- terminals of the N900 battery. I measured with a multimeter once in a while to make sure I did not overcharge the BL-5J. After sufficient charging, I slapped it back into the N900, and it worked like a charm. Those who are particularly uncreative should attempt to buy a replacement battery before turning to other, more extreme measures. This is a frustrating issue to deal with, so in the future, never let your N900 discharge completely! Hope this helps.
Unlocking code for nokia n900
Get the unlock code for Nokia N900
Unlock Nokia N900 phone free in 3 easy steps with Unlockninja a leading provider of Nokia Unlock Codes can locate your Nokia N900 Unlock Code fast and easy way and you can use it on any network SIM after Unlocking is done.
Unlock Nokia N900 How to Unlock Nokia N900
Jul 11, 2018 | Nokia Cell Phones
My nokia n900 fn is locked. how to unlocked?
Hi, You can unlock your Nokia N900 safer and easier using unlock code. You can get the unlock code from www.onlinegsmunlock.com/nokia-n900/rs7wp9/ at affordable cost .
Here are the steps for unlocking a Nokia N900,
1 - Switch on your Nokia N900 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N900.
3 - Compose #pw+CODE+1#.
4 - The Nokia N900 would then display the message "SIM Restriction Off" and will be unlocked!
Sep 08, 2012 | Nokia N900 Smartphone
N900 camera showing black screen
Please switch on the camera, if you have enough charge on the camera.. or else charge it.. Even after switching on the camera, if it is black, then screen might got have damaged.. Service it if you have warranty..
Apr 01, 2012 | Nokia N900 Smartphone
Nokia n900 restore original settings code
i want restore my Nokia N900
i want restore my Nokia N900 mobile. My IMEI No is 356938036549708 but System asking pin number also. how can i get thet PIn number. How to...
thank you
by www.oktaviona.com
Jan 07, 2012 | Nokia N900 Smartphone
How to unlock n900 from us to philippines
It simple to unlock the Phone from Network lock,you can get the Unlock code from the site
www.classicunlocking.com and UNLOCK it, you can follow the instructions below and unlock it step by step...
Nokia N900 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N900 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N900 mobile phone, your phone may get hard locked and sometimes become unusable.
Note :For Nokia N900 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N900
Oct 13, 2011 | Nokia N900 Smartphone
My Nokia n900 is not charging fully especially using the wall socket charger, i love this phone only this problem. thanks!
Ifthe is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.If the battery drops to an unacceptable chargelevel then the battery needs to be replaced.
Jan 20, 2011 | Nokia N900 Smartphone
The problem with my nokia n900 is when the battery finsh and the phone turn off icant charge my phone nokia n900 can you help mee plzzzzz
Remove and re-install the battery. Keep the phone switched off and connect the charger. Wait a few minutes before you attempt to switch it on again. If this does not work, your battery is fried due to deep discharge and needs to be replaced.
Update the Maemo 5 operating software on your phone, the current release removes a lot of software problems, including the charge blockade in low battery situation.
Dec 13, 2010 | Nokia N900 Smartphone
N900 freezing and turning off
My advice is to download the latest firmware from Nokia website (which is version PR1.2) and install it through the USB cable provided to you. If this is something you can not personally do, please go to an authorised nokia service point and have this done for you. They should NOT charge you but ask about that before. For the battery removal issue, there is a way to bypass this process. Please press the power on/off switch for about 10 seconds. normally the device will unfreeze and go off without having to remove the battery. wait a few seconds and then you should be able to switch it on again.
thank you :-)
Jun 30, 2010 | Nokia N900 Smartphone
I have a yellow glow on my N900 and it will not turn on anymore with new battery....please advise
I recommend a firmware / system software upgrade & replacement for your Nokia N900. Full instructions are available here.
I hope that helps.
Mar 13, 2010 | Nokia N900 Smartphone
Nokia N900  Smartphone Logo
981 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
