Question about Stanley Bostitch MIIIFN Flooring Nailers
Cleats will not go in all the way and the nailer seems to bounce too much. We are trying to install unfinished pine tongue and groove. Please help!
    Problem Solver:
  • 13 Answers
You may have too long of a cleat, also check your psi on the compressor. you should have 90 psi and ajust from there
Posted on May 25, 2010
Where can I get Original Victorian Pine Floorboards? I am looking for it since 2 months.
You will get Original Victorian Pine Floorboards online at The Reclaimed Flooring Co, here you will find Original Victorian Pine Floorboards and Edwardian pine floorboards which have become increasingly difficult to source in recently years. Get them to your living room floorboard today! Original Victorian Pine Floorboards The Reclaimed Flooring Company
Dec 01, 2014 | Cars & Trucks
Nail won't set to allow tongue to enter groove
Your nailer has variable sized plates /shoes bolted to the bottom. I believe that there are about three different thickness available. Take a look at the link below for a parts list showing the sizes available. For a quick fix to drive the cleat deeper, use a thinner bumper below the head of where you strike the nailer. If you manually push down the striker, you can see how much of the driver comes out the bottom. The bumper below the head (black rubber washer) cushions the striker against the body of the nailer. A thinner bumper (you must be creative here) will allow the driver to extend out slightly more. Good luck with your flooring projects.
nailer-parts-c-29443_29458_29679.html">http://www.ereplacementparts.com/bostitch-mfn201-flooring-nailer-parts-c-29443_29458_29679.html
May 30, 2011 | Stanley Bostitch MFN201 Factory...
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
The staples are not going deep enough into our hardwood. We tried a different nailer as well, and the cleats wouldn't work either. Tried both 1 1/2" and 2" staples and cleats. We're installing 3/4 inch oak...
The working pressure of this tool is 85 - 90 PSI max. Do not over power it or you risk O-ring breakage. These guns are adjustable for floor thickness. The adjustment is simply by adding and removing shims on the floor contact part of the tool. For 3/4" the pad should be 5/16" thick without shims
Jan 03, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
How to adjust the nailer, flooring is 5/8",so the cleats sit where it should be? How to avoid splitting the tongue on the wood?
You must put an in-line regulator at the inlet for the gun. Turn your preasure to 90 psi and use a sample board to get the fine tune adjustment at the gun. Turning down the air preasure will reduce the amount of force the anvil hits the nail with.
Nov 18, 2009 | Craftsman Nailer Kit, Palm Air Driver
WHEN I DRIVE A CLEAT INTO THE FEMALE GROOVE OF THE T&G IT STOPS SHORT OF DRIVING IT ALL THE WAY SO THE NEXT PIECE FITS SMOOTHLY. CAN U ADJUST THE DEPTH OF THE STAPLE? THIS IS USING THE BOSTICH MANUAL...
I assume you are hitting the driver square and hard. You can't baby a floor nailer. If hitting the driver is not the problem, the driver that contacts the nail could be chipped or broken. It's not unusual, especially if you've used it on hickory or maple. Compare it to a new one to see if that's the problem.
Nov 04, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Bostitch M111 not driving the staples far enough into the floor.
When this happens it is most likely the piston has untreaded itself from the piston stem. This will cause the piston to hit the bumper before it drives the nail all the way down. You must dismantle the tool and tighten this piston up. Or take it to your nearest Bosttich service center its a pretty quick fix.
Hope this helps
Mar 26, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
With a stanley floor stapler do i nail at tongue or groove
the staple goes in the corner of the tongue, angled back into the board at 45 degrees, to make an invisible staple, the next board groove covers the staple and tongue. The floor nailer is preconfigured to make this joint
Oct 04, 2008 | Air Tools & Compressors
Stanley Bostitch MIIIFN Flooring Nailers Logo
597 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
