Question about Toshiba Satellite A100-S8111TD Notebook
How can I get my screen back on?
My laptop won't do anything. I turn it on and the screen stays dark, it makes a noise like it is starting up, then nothing. My sister had a guy "fix" it last time this problem happened, he said it was a button I must've accidentally hit. She said he hit F5 ad one other button and it worked fine. That was a few weeks ago. Now, I need it to study for my college final tomorrow and it won't turn on! what buttons do I need to push?
  • 185 Answers
Ok maybe what happened is that you accidentally enabled the external monitor function. That is when you want to connect your computer to a monitor, projector, etc. your monitor will turn black and you will be able to see the other monitor. most computers you have to press the keys Fn+ either f5 or f8 that will return to your screen.
if the configuration on your keyboard is different look for the key that says CRT/LCD and combine it with Fn if you can not find it try Fn and all the f keys on top (Fn+f1, f2, f3, etc) when you do that wait a few seconds to see if your monitor reacts.
if it works for you don't forget to rate me
thx
Posted on May 14, 2010
Laptop screen won't come on
The problem could be as simple as the hinge switch that switched off the backlight when you close the cover. If the computer seems to start up, but you just can't see anything, wait until the unit has had enough time to fully come up to either the login screen or the desktop (however it's configured to start). Look VERY carefully at the dark scrren to see if you can just make out the login graphics or desktop icons. If you can, then the unit has booted up ok, but your LCD backlighting is not working. This could be because the backlight lamp is defective, or its power supply may be defective, or the little switch back near the hinge of the case is stuck or defective. Check this first.
Jan 15, 2012 | Computers & Internet
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Screen is dark at start up
If its running on batteries the screen brightness will dim quite a bit. If on AC adapter it should be full brightness, but this is adjustable in either case. With the computer up and running, press and hold down the Fn key and push the up arrow to make it brighter and the down arrow to make it dimer.
Sep 16, 2009 | Dell Studio 1537 Laptop
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
My screen remain dark when my laptop is turned on.
If you can hear the sound of Windows starting up, your blacklight probably died. If you can't hear the Windows start up sound, Windows may need to be re-installed. Most likely though, it's a faulty backlight.
Please rate, Thanks!
Oct 03, 2008 | Aspire Acer 7520-5324 Laptop
HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
1) Turn off your laptop.  2) Remove Power supply.  3) Remove the battery and put it back again after 1 min.  4) Put power back and restart.
This should solve the porblem ! I have had it several times.
May 06, 2008 | HP Pavilion dv6000z Notebook
Toshiba m35x-s161 won't do anything...
can you access the bios if so reset to default and restart if you cant start up to as far as you can get then try a soft boot (ctl,alt,del all together at once) failing this you could try insert system disk and try to reboot and see if it try to install new copy.if you can get to any of these positions you can reset bios by unplugging and reconnecting rtc,this requires dismantling laptop,i may have service repair manual for your pc ,have to check
Feb 22, 2008 | Toshiba Satellite M35X-S161 Notebook
Dark Screen
sounds like a faulty Backlight.. If you just bought this take it back and get it replaced, Check if the Manufacturer's warranty is still valid. if this was bought second hand (out of warranty) I would take it back. as it is unlikely that the prev owner did not know of this issue.
Nov 03, 2007 | Supersonic SC-299TDVD
Toshiba Satellite A100-S8111TD Notebook Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
