Question about InFocus ScreenPlay 5700 Multimedia Projector
In the start up menu vertical white stripe lines appear
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
There is a connection behind the lens assembly that plugs into the main board, clean both ends with an approved cleaner and reseat the connection. this should hopefully fix. if not it is the main board or the dmd board on the lens assy.
Posted on May 19, 2010
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
I have a HP 2035 lcd monitor that has a 3cm yellow vertical stripe running though the middle of the screen.
I have smth same... my monitor as gets warm, has a vertical stripe that become blurry, then it becomes worse till the white or black striped, like a zebra line appears? Some electricians have changed the condensators, have put the radiators to reduce the heat, hell knows what is with it, I really like it but no1 can fix it... any1 have any ideas?
Aug 29, 2010 | Computers & Internet
One day my tv started having white lines in various places, then one day the scrren went white but still has a small line across the top that works fine
The problem is "Vertical Over-drive" and the white lines are vertical retrace lines. What has happened is a component failure between the vertical oscillator and the vertical driver circuit. The component is usually a capacitor that is leaking and allowing voltages to appear where they shouldn't be.problem component is leaking and allowing DC voltages to appear where they don't belong. It's causing the vertical driver transistor to run "flat out" and will ultimately burn out the transistor from internally generated heat.
Hope this help....
Jun 18, 2010 | Televison & Video
Vertical colored lines on white background on SyncMaster 740N
Hey dont open the LCD in a hurry......the problem may be due 2 usage of LCD 4 long time better dont on the pc for a day........or in night time keep it under the fan.......this may give a better result........
Nov 09, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung monitor has white background with vertical color lines
if you have got access to another monitor try that it may be the computer or try another computer on the monitor hope this helps regards Jim
Apr 20, 2009 | Samsung Cell Phones
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
InFocus ScreenPlay 5700 Multimedia Projector Logo
382 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
