This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
Testimonial: "your information was very helpful, i just wish i knew more about tvs so i could find the right part"
Pick from the wesite Menu call Samsung/Akai circuit board. Sorry $169.95 to be exact to buy this rebuilt Samsung/Akai tv convergence board.AA95-02002A Convergence Amp PCB rebuild option.Talk to the website employee,to discuss more..
When you pull the back off, the convergence board will be located upper left side of cavity. It will be mounted on a heatsink(metal bracket with some sort of fins for cooling) which in turn will be mounted on the CRT crossmember. There will be 2 black rectangualar hockey puck looking devices mounted to the heatsink and PCB. Should be labeled STK392-040.Check FD1028 and FD1018 located right of each IC and looks like a solid green colored resistor. These are the fuses for each ic. If open then the ic coresponding to it is blown! Also check all of the half watt resistors on the board. The convergence modual p/n is: AA95-02002A for those that would rather not go to component level.
Thank you that was helpful. I'm glad I know what thte problem is now but, I'm sorry I don't know alot about TV's. What is "2 STK convergence ICS" and how do I know what convergence board to get? I looked on tvrepairworld.com but, I've got no idea what I'm looking for.
