Lexmark 5070 Scan issue
Trying to scan and all the Lexmark 5070 says is downloading application list and it doesn't do anything else
  • pumpkinpie47 May 14, 2008
    trying to scan and the Lexmark 5070 and it is stating downloading application list and it doesn't do anything
  • Anonymous Mar 13, 2009
    same problem
Says i am missing the program required for editing
Posted on Nov 17, 2008
My s301 won't scan. Won't download application list.
Try scanning from Lexmark Printer Home. To do that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
Jan 02, 2013 | Lexmark Impact S301 Wireless All-in-one...
Lexmark X4580 (all in one wireless)
HI,
You can try out these two options one by one to fix it up:
A)
1 Unplug the printer.
2. Uninstall the drivers.
3. Reboot the machine.
4. Go to the lexmark site and download the drivers.
5. Install the new drivers.
B)You will get the "CANNOT RETRIEVE APPLICATION LIST" if your pc blocks the communication from the printer. This can be configured in your personal firewall. This can be Windows Firewall (found in Control Panel, Security Center), Symantec Client Firewall or similar. Depending on the configuration of this firewall you might or might not get pop-up messages from the firewall during installation. These pop-ups will allow you to permanently allow for this incoming communication. But your firewall might be set not to let you decide anything which will typically mean that the calls will be blocked out. This will often be the case if you have a company laptop configured by the company IT dept. You might then have to ask an admin to add exceptions the applications used by Lexmark as the configuration might not be open for you to change.
I think this is the complete list of applications:
Job Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdijswx.exe
Lexmark Communications System: C:\WINDOWS\SYSTEM32\lxdicoms.exe
Lexmark Connect Time Executable: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxditime.exe
Lexmark Device Monitor: C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
Lexmark Imaging Studio: C:\Program Files\Lexmark 3500-4500 Series\App4R.exe
Printer Communication System: C:\WINDOWS\SYSTEM32\lxdicfg.exe
Printer Status Window Interface: C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32X86\3\lxdipswx.exe
Goodluck,
Please don't forget to rate the solution.
Apr 17, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Lexmark x5650 cannot retrieve application list
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 16, 2012 | Lexmark X5650 All-in-One InkJet Printer
Wont scan lexmark x6675
Try to scan by pressing the scan button on the printer, if this works. Then try to scan from the application that came with the printer. Please let me know the results.
Sep 03, 2009 | Lexmark X6675 Pro Colour Wireless...
I have a LEXMARK X5650 that will not SCAN to the computer... When I press SCAN it does nothing. So I press the ON and START buttons... The display will then say "Scan to Computer" - If you click "OK", then...
When using Adobe Photoshop, select File, then Import, and then the Lexmark device. That's the only way I have found, however you should be able to scan through many programs.
Mar 08, 2009 | Lexmark X7350 All-In-One InkJet Printer
Cannot scan with Lexmark x4550
Hi
Uninstall driver,,,,restart computer..reinstall driver...if its a vista operating system..try the downloaded drivers from www.lexmark.com.
goodluck
Jan 25, 2009 | Lexmark C533DN InkJet Printer
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Device monitor application problem
Make sure that the Lexmark Imaging Studio program is running. This was installed when you set up your printer.
If you see the multi-colored icon in your task bar for Lexmark Imaging Studio then try pressing the scan mode button twice. You should be able to scan then.
Sep 28, 2008 | Lexmark X3550 All-In-One Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' -----> 'From scanner or camera' (while the Lexmark is in scan mode). Just tried it and it really works.
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
