I have an insignsa ns-lcd42hd-09 (I have 2 of thies) It will come on,the screen will light and no sound. A blue box says wait, then it goes black. I have swaped out the main tv board and p/s board from the other tv that would at least stay on and pull up the menue.Whats next?
  • rknight2 May 14, 2010
    Just noticed that only the lower half of the screen lights dimmly then shuts gowes black Ihave a second set it had bulb problems. So I replaced the first sets p/s and main board same problem. I'm looking at the lamp inverters next. what do you think?
  • 979 Answers
Hello Rknight2, hi, as you have describe, the LCD lower half is dimmed, this is an LCD failure, you need to swap the LCD with the other, and see if the trouble is solve. does the two LCD TV you have are both defective? its hard to test if both TV are defective, you must first sort out which is defective and which are good. but you need to put all the good parts on the TV with a good LCD screen. as for the inverter, test it first, swap a good one, get one on ebay if both inverted are bad. DID you test if the P/S and main board are good? make sure they are good and put them on the TV with the good LCD screen, get one from ebay if both boards are bad.
Posted on May 15, 2010
  • 1 more comment
  • rknight2 May 15, 2010
    Thanks you are the first not to insult my 40 yrs of exp. Lets call the set I'm not trying to fix "set 2" and the one I'm fixing "set 1" . set 2 had broken back light tubes so I swapped out the inverters from set 2 to set 1the one I'm repairing . All lamps light now but only for a second. I checked the voltage on the p/s board and to the other boards , all ok. the tvs were used in a factory as computer monitors. that were they went bad. sense the boards from set 2 are in set 1 I would think set 1 would behave as it was set 2. you sound knolagable, please stay wiht me on this.
    p.s. the power light is red on standby and blue on run and the fiber optic port is lit. when turned off the red light blinks 7 times?
    Thanks
    RKnight2
    May 15, 2010 - Thanks you are the first not to insult my 40 yrs of exp. Lets call the set I'm not trying to fix "set 2" and the one I'm fixing "set 1" . set 2 had broken back light tubes so I swapped out the inverters from set 2 to set 1the one I'm repairing . All lamps light now but only for a second. I checked the voltage on the p/s board and to the other boards , all ok. the tvs were used in a factory as computer monitors. that were they went bad. sense the boards from set 2 are in set 1 I would think set 1 would behave as it was set 2. you sound knolagable, please stay wiht me on this.
    Thanks
    RKnight2
  • Jerry Umali May 17, 2010
    Hello Rknight, hi, the 7 blinks you describe is still a power supply failure. the TV is on standby mode, this occurs when power required by the TV is not enough, there is a need for you to check the main board for shorts, both set1 and set2, now to do this, you may need to swap out both set1 & 2 to or for a good main board.
I have a sanyo dp42848 tv the screen goes black after a few seconds but still has sound
The model listed here does not use a bulb or lamp and most likely not a do it yourself repair---consider having a shop look at this and get a estimate.
Oct 22, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Insignia tv light blinking red and blue
you have a faulty parts inside..try to disconnect one by one the supply of all board until you get stable lights..
Jun 14, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I have a insignia ns lcd42hd 09 tv that on the left half of the screen has ghost images and sometimes vertical lines in it and i noticed when i shake it the screen goes back to normal but i have to do this...
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Sep 07, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Hello, I have an ns-lcd42hd Insignia TV I'm looking for the part number for the factory remote.My son lost it and I'd like to purchase a new one thank you
As for the part number... not sure. But you can purchase a new remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NS-LCD42HD-09&uuid=12749564580310
May 27, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
RE; NS-LCD42HD-09 THE COLORS ARE TERRIBLE. THE
Here are some preferred settings for the same model in 32" It should get you close enough to fine tune from.
  • Picture Modes
    • Picture Mode : N/A
    • Color Temperature : Warm
    • Aspect Ratio : Wide
  • Precision Settings
    • Contrast : 60
    • Brightness : 50
    • Color : 52
    • Tint : G1
    • Backlight : 3
  • Advanced Video Menu
    • Noise Reduction : Off
    • 3DYC : Off
    • Dynamic Contrast : Off
Dec 25, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
NS-LCD42HD-09 Insignia. The power light is on, but no sound, no picture. TV is 13mths old. Best Buy junk I'm guessing, but as a electrical engineer, I'm determined to fix it myself. I think it's the power...
At least the 5VDC stand by power supply is working, there will be a control signal pin from the mainboard to the power supply board to turn on the rest of the power supplies (24vdc for the back light inverter boards, 12vdc for other circuits). Any bulging caps in the power supply?
Nov 24, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I have an insignia model ns-lcd42hd-09 hdtv that show the number two(2) on the top right side of the screen. How do I get it to go away.
The problem originated in the HD cable box. I turned off the box for about 10 minutes and after the power was restored and the reset was completed the problem disappeared.
Nov 17, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
