Question about Stainless Garden Sun Steel Propane Patio Heater
The pilot light will light but when you turn it to the on position it goes out
I replaced the thermocouple and I can not get furnace to light.
turn to pilot to light pilot
hold and wait should be instructions on control
turn to on position if pilot goes out start again
Nov 02, 2015 | Heating & Cooling
How do I light my janitrol ucs100-55 heater?
you need to turn on the gas supply. then turn the button on the valve to the "light" position. now press down that button repeatidly until the pilot light lights, when the pilot lights you will need to hold that button down for about 15 seconds. then when you release the button the pilot should stay lit. when it does... turn the button to the "RUN" position. thats it... turn up the thermostat and the heater should kick in.
Jan 06, 2015 | Heating & Cooling
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
How to light pilot light
put to pilot position hold button down for a minute while holding light pilot generator that's where small silver line from gas valve goes under to burners lite there hold for 1 minute (to let pilot generator to get hot) then turn to on position it should work then turn on button on then
I have a Rheem gas furnace, model # RGAA-100C and need help lighting the pilot. The instructions on the metal plate tell me to set the valve to off, then to pilot, push the valve down until lit, and then...
Hi, follow what I say and it is very easy. The knob that says off, on, and pilot, is where you need to start. You don't want to turn it off now, as its been off for awhile now. Turn the knob slowly pushing down on it until you fill it go down. The knob will go down believe me. When this happens, keep holding it down as this is what starts the gas to the pilot which is back under the burner, under it. Just take a flash light and you can follow the aluminum tubing back and where it stops is where you light it with something long with a match in it or a small rolled up paper. Keep the knob down the whole time you are lighting it. When it lights, keep the knob pushed down for about another minute. Then slowly release the knob and the pilot should stay on. Once you have it on, turn the knob to on, not off. If you turn it the wrong way, it will go off and you will need to start over again. Once it stays on by itself, turn your thermostat up for heat and the burner will light and come on. Just remember that the pilot where you light it is where the tubing goes back under it, as the pilot gas goes through it. You will need a light. Look at the knob with a good light and it will tell you which way to turn it. In the pilot position, the knob will press down to let the pilot gas in, and you can reach back and light it. Then turn knob on. Pilot should stay light. Turn on thermostat and it will fire up. Let me know how it goes. You may have to try a couple of times.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 05, 2010 | Heating & Cooling
Will not light, the pilot light comes on but when I light the knobe out to turn it to the on position the pilot light goes out.
Dirty pilot safety most likely.If dust gets into the ODS chamber the safety feature will think the oxygen in the room is low and shut down. I would try cleaning it first and if that don't do it then the thermocoupler is weak not holding when the valve is advanced to the ON position. I have some Literature HERE and a nice movie which features the safety pilot in action HERE
Jan 24, 2010 | Heating & Cooling
Gas Fireplace pilot light continually goes out
You may have a problem with the flame sensing capillary. It may need to be replaced, or it may need to be positioned into the pilot flame better, or you may need a new gas safety valve. Sometime there is an adjustment screw for the pilot which can make the flame bigger or smaller. If will be on the safety valve.
Oct 14, 2008 | Grilling
Stainless Garden Sun  Steel Propane Patio Heater Logo
73 people viewed this question
Top Stainless Pool & Spa Experts
Merv Vickery
Merv Vickery
Gene Haynes
ray gallant
Are you a Stainless Pool and Spa Expert? Answer questions, earn points and help others
