Question about HP PSC 2410 All-In-One InkJet Printer
Getting cartridge in
I cannot get the cartridge in the slot!!!!!!!!!!!!!!!
    Master:
  • 518 Answers
Go HERE and read the Setup Poster. You may have to zoom in a bit, but it shows exactly how to do it.
Hope that fixed ya...
Geno
Posted on Mar 30, 2008
How do I replace ink jet in officejet 4500
Step one: Remove the old cartridges
1. Press the power button to turn on the product
2. Open the front access door. The carriage moves to the far right side of the product
3. Wait until the carriage is idle and silent, and then lightly press down on the cartridge to release it.
To replace the tri-color cartridge, remove the cartridge from the slot on the left.
To replace the black cartridge, remove the cartridge from the slot on the right.
Pull the cartridge toward you out of its slot.
Step two: Install the new cartridges
1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
2. Gently remove the plastic tape by pulling the pink pull tab
3. Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot. Make sure you push the cartridge in firmly until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black cartridge, slide it into the right slot.
4. Close the front access door.
May 27, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
I have an HP OfficeJet V40xi. My problem was getting an "cartridge black installed error" but it was properly installed! I am not try replacing with other cartridge yet...that might it be the...
The cartridge slots are not interchangeable so you will not put the color in the black etc.
Many HP printers will detect third party and re-filled ink cartridges and refuse to accept them. There is no way to override this in the software package.
I had a third party re-man ink cartridge work for two days and then the HP decided it didn't like it.
Apr 15, 2011 | HP OfficeJet V40xi InkJet Printer
How do I install the ink cartridges for the MP210? The instructions in the machine aren't helping.
You have to install the ink cartridges all the wy into the appropriate slot.
The black cartridge install into the left slot ( B )
Color cartridge into the right slot ( C)
Push up on the ink cartridge until it clicks into place.
The cartridges are install at a slight angle, when it up against the slot,
push up on the cartridge.
Mar 02, 2011 | Canon PIXMA MP210 InkJet Printer
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
I installed new ink cartridges in my hp printer and still get a message asking me --- install new ink cartridge to continue.
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Jul 16, 2010 | HP Photosmart D7460 Printer
Ink is stuck in the printer. I can't get it out.f4280 deskjet
I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
To replace the print cartridges
1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
2. Open the print cartridge door.
The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black print cartridge
4. Pull the print cartridge towards you out of its slot.
6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing the black print cartridge, slide it into the right slot.
Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
I replaced the toner cartridge on my laser printer but it isn't fitting properly the door will not close all the way therefore it gives me a message saying ''cartridge is not engaged''. I removed all tabs...
Try putting one of the other cartridges in the black slot. And put the black in the open slot. Do they fit and can you close the door?
If the black is ok in the other slot, and the cartridge in the black slot doesn't fit correctly...you need the cartridge locks replaced. You can not do this. You have to get a printer tech to install the locks. And make sure that all 4 get replaced.
Nov 23, 2009 | HP LaserJet 3600n Printer
I put the cartride in the wrong spot how do i get it out.
If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
Pull the print cartridge toward you out of its slot.
If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector
Regards,
Jeep Brainy
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Officejet 5610
Thanks for trusting me Arthur84
Bad News that you have put the wrong cartridge in the wrong slot.
If you call HP they will replace both the Cartridge and the All-In-One as this is not possible to take out the cartidge from the wrong slot.
But if it is possible please apply little more pressure and try to take the cartridge out from the slot and try replacing it to the right slot.
If your printer is still in warranty then you can get both the cartridge and the All-In-One Replaced for free, if not you may opt for the Out Of Warranty Upgrade option Through HP Tech Support.
Good Luck Arthur.
Sep 05, 2008 | HP Officejet 5610 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
