Question about GE Spacemaker JVM1640SJ Microwave Oven
I took panel off to change out magnetron and forgot where the wires go to reattach touch panel can anyone help me with a picture diagram.? its is model jvm1650sb004
  • 5,603 Answers
If nobody responds with a diagram, you might go to an appliance parts seller and find information in their catalog photos.
Posted on May 14, 2010
Spacemaker: Unit starts up after entering clock data then shuts right down upon cook cycle. Then asks for clock/date data again. bought new in 2005
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in GE's bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
One way to test it is to do the following:
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net (posted with permission by copyright holder)
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. )If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.)
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions
here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help
here. I'd recommend that your bookmark this link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find links to helpful exploded view diagrams and part ordering help here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Jan 15, 2010 | GE Microwave Ovens
Loss of power during use
You didn't mention your brand or model, but I'd bet it's a GE/Hotpoint or other Samsung-made oven.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net (permission granted by poster-author to FixYa to keep this document on their site intact)
6. Shut the door.
NOTE:
here.
Dec 25, 2009 | GE Profile Spacemaker Over-the-Range...
Will not heat food. Microwave operates normally, it just does heat the food. Every once in awhile the LED display will flicker, and a couple of times the unit turned itself off.
6. Shut the door.
NOTE:
here.
Dec 25, 2009 | GE JVM1440 Microwave Oven
Microwave quits and requires clock to be reset. Reset it 3 or 4 times, then it may work for awhile. GE Spacemeaker
NOISY MAGNETRON TEST (c) 2009 and posted by William E. Miller prototech@usa.net
(I the poster am the copyright holder on this and hereby grant permission to this site keep this on its site)
6. Shut the door.
NOTE:
here.
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave oven starts and runs for a number of seconds and then shuts down asking to reprogram the date, time ect
6. Shut the door.
NOTE:
here.
here.
Nov 28, 2009 | GE JVM1660 Microwave Oven
When we use the microwave sometimes after about 5 seconds it just shuts off and resets everything as if it lost power. It does not do it everytime.
Since this is posted under GE, I'll assume it's a GE.
6. Shut the door.
NOTE:
here.
here.
Nov 23, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave shuts off after afew seconds
The shielding may keep the interference out of the controls, but it's still being emitted, and the magnetron will eventually go bad.
6. Shut the door.
NOTE:
here.
You can find helpful exploded view diagrams and order parts by entering your full model number
here.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 09, 2009 | GE Microwave Ovens
It runs 2 seconds then stops You have to reset the clock and date to get it to work again its about 4 years old
6. Shut the door.
NOTE:
here.
here.
Oct 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Micro wave shuts down in 3 seconds
This is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details are
in their bulletin here.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On Samsung models there are L-shaped clips that fit into a slot to hold bottom of the vent.
6. Shut the door.
NOTE:
You can download GE owner's manuals and installation instructions here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
May 24, 2009 | Samsung MS1040BB Microwave Oven
The microwave will only stay on for a few seconds
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
6. Shut the door.
NOTE:
May 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
143 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
