Question about Rinnai Toyostove Direct Vent Heater: Laser 56 Toyostove Direct Vent Heater
Laser 56 howls or sounds like a horn when transitioning from high burn to medium burn and has a high yellow flame. How can I fix this? thanks
  • 674 Answers
The high yellow flame is probably due to a loose burner mat or a warped burner ring or both. As for the howling I'm not sure about that but would be related to the airflow, maybe something to due with the blower.
Posted on May 14, 2010
  • 28 Answers
Got to agree wit Brain, My Mr Heater was singin' "Sweet Marmiduke"! Not to mention it wasn't heating very well. Both burner screens had holes at the top. So I unscrewed them both and turned them 90 degrees and bolted them back down . What a difference ! It quit singin' and heated a lot better. I only wish I would have tightened the whole assembly first. RG
Posted on Jan 10, 2013
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 howls like a banshee, but only when burning on medium (yellow light) Just serviced by authorised tech. Replaced burner mat, heat chamber gasket, vent gasket, and fuel filter. Did not have this...
He might of gotten cleaner into the berings on the blower motor which will make it squeel like a dirty bearing sound.
If it's a low howling noise check that the squirrel cages are tight and not slipping. Also check for restrictions in the air intake.
Oct 29, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 56 H burner coating or burn mat
Here's a link regarding burner mat replacement for a 56 if you have not already figured it out.
http://www.rural-energy.com/publications/catalog/document/318
Nov 26, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove 72 won't go on high.
Replacing the burner ring (center piece?) will do wonders. When it's warped the stove won't work properly.
Jul 22, 2008 | Rinnai Toyostove Direct Vent Heater:...
Vulcan Oil Heater
move the collar away from the orifice for a blue flame. too little air causes incomplete combustion so you get the yellow tinging
May 18, 2008 | Heating & Cooling
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
Feb 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo 56
Hi ejohn,
There is no valuable, practical adjustment for the flame on a Toyo Stove. A yellow flame can be caused by several things. How old is the stove? When was the last tune-up? A dirty sooty carboned up stove will have a yellow flame. A breach in the flue pipe will cause a yellow flame. An incorrect installation of the flue and exhaust hoses/metal exhaust elbow will cause a yellow flame. In the last scenario, the intake will be hooked to the exhaust and the exhaust will be hooked to the intake ports of the flue pipe. A malfunctioning fuel pump can also cause a yellow flame. The wrong fuel can cause a yellow flame, too. Most likely, your stove is dirty and needs a tuneup. It should have a bright blue flame if it is clean, and operating correctly. You can download a manual at REE, Anchorage through a Google search. If you want a more detailed diagoses, write back and give me more detail and I can help you further. Toyotech
Jan 30, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? The firing process is the burner button blinks green for 7-9 minutes, then it clicks up to the medium, yellow light which starts flashing. That is when the fuel pump starts pumping. If you hear a fairly audible tic tic, or thump thump coming from the fuel pump then that is your indication that the fuel pump is starving for fuel. You either have a fuel line restriction, too little fuel, a clogged filter, a clogged sump screen, or rarely, a failing fuel pump. Usually, it is a fuel line restriction.
If you hear no tic tic or thump thump and it just goes off on EE2 then the problem is in the burn chamber. You may have a carbon chain in the chamber causing the flame sensor to temporarily short out. You can clean the flame sensor, fuel nozzle, and igniter to resolve this problem until you can get your Toyo tuned up.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
471 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
