Question about Cell Phones
Our machine is all hooked up but even tough you switch it on to the answering machine choice, it doesn't activate when calls come in
    President:
  • 1,561 Answers
Follow the procedure below to activate your answering machine, perhaps, after the activation, your answering machine should be able to answer incoming calls.
Call your telephone number and wait for the answering machine to answer. If you have left the answering machine in the off state then you should let it continue ringing until the machine finally answers, this may be as many as ten rings or more. When the machine finally answers, you may hear a series of beeping sounds.
Press "0" during the playback of the greeting message or during the series of beeps. Enter your PIN code within the next 2 seconds. You must know your PIN code to operate the answering machine remotely.
Wait for the prompt to enter a command code for remote operation. You will hear the machine report the current time and how many messages are in memory. The machine will then play a beep and wait for your command. To turn on the answering machine you must enter the corresponding code. You must enter the remote command within 15 seconds.
Hang up after the machine finishes the command and beeps. Call back to your number and make sure that the machine is now in the on state and will answer incoming calls.
Take care.
Posted on May 14, 2010
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Aug 21, 2015 | Dell Office Equipment & Supplies
Uniden d1680 answering machine doesn't record messages, only dial tone.
If the system doesn't answer the call at all then you need to turn the answering system on. If it answers the call but does not record a message then you need to turn "Announce Only" off. Both of these are in the Answering System Menu options described on page 13 of the manual.
Apr 18, 2012 | Uniden D1680-3
I have a Panasonic cordless phone.. kx-tga 233w. A call is received, but I can't answer it. It is saying Ringer off and have searched a way to turn the ringer on. A light flashes when a call is...
Try checking the modes of the phone. there are different choices like "airplane mode" which forwards all calls to your voice mail. You can see the calls coming in, but you are unable to answer them. Your phone is probably set to airplane mode. Modes are listed under calling preferences. Other examples of modes are background mode, normal mode, outdoors ect. If you cannot locate these modes under calling preferences contact your service provider and have them help you find them.
Aug 17, 2011 | Lands Phones
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
I want to stop a certain caller from contacting us, without the dispay 00 going off, so my family member doesn't know they called. How do I do it. or can it even be done?
There is a service provided by your dialtone provider called selective call rejection. Call your service provider have them turn the service on and you can add the phone numbers of the calls you want rejected and they won't show up on caller ID. The is a cost associated and varies with provider.
I hope this helps. Have a great day.
Jul 09, 2011 | BellSouth Digital Answering System 2006C...
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
The model of my AT&T answering machine is 1720...it is linked to a Brother's fax machine...when a call comes in I am not able to pick up the phone and interrupt the message from the answering machine...
Connect the telephone line of the answering machine from the series connection of the facts machine
.Now set the number of rings for the answering machine to activate to the maximum.{This is found on the side of the machine as a reed switch.}
Now when the calls comes in there is enough time for you to allow it to the answering machine or to attend a call or to set it to facts if a document is comming.While you are away you have to decide the priority needed for either facts or answering as it is a commonline. If answering machine has to work set the facts to telephone mode.If facts has to work set it to facts as the machine will activate before the answering machine.
Sep 02, 2010 | AT&T Lands Phones
Would like more than 4 rings until machine answers
TS is the Toll Saver Option.Sometimes this will let it ring many times, before answering.
4 rings is the maximum setting. You might try the TS, then try calling to see if that helps.
Apr 28, 2009 | Lands Phones
Answering maching
I would start by testing the phone while you are standing next to it. Call yourself from your cell phone and see if your answering machine is actually picking up.
My guess is that somehow the voicemail service from your telephone company got activated and the phone never rings long enough for the answering machine to pick up.
The other possibility is that your answering machine got set to "announce only." You don't specify what exact model you have but on mine (which is a Vtech 5.8GHz model with multiple handsets) you turn the answering machine on by pressing the on button and then use the menu button to cycle through the choices. One of the choices is "set announce only." When you are on that choice press the change button. If it says off, then it is set correctly. If it says on, press the change button again to alter the setting from on to off.
Sep 24, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
