Question about Taiwan Semiconductor Co. TSC TTP-243 Thermal Printer
How to replace the printhead of Clever TTP 244 Plus
Call TSC Orlando office 407-704-8918 for tech support
Posted on Jul 22, 2011
In my application,i want to print the barcode generated from the application.i am using TTP 244 plus printer for printing the generated Barcode.but printer skips two lables and print the generated bar
Please verify the following:
- Driver: If you are using the standard printer driver, maybe you want to try another driver(Download an excellent driver at www.nicelabel.cl, searching by your brand and model name).
When installed, you should go to advanced settings and use the callibrate options.
- Software: Maybe your software has a configuration and the driver has another, set the same length for both and verify if the problem persists.
- Sensor: If the sensor has an issue, then you should try contacting a local reseller or partner for zebra. If that's the case, you probably will have to repair the printer($) or definitively replace it for another($$). Since it's a desktop printer, check your warranty first and maybe you are covered.
Jan 16, 2015 | Zebra GK420t thermal transfer and thermal...
Hp 6500a plus printhead won't print
As you said that you have already cleaned the print heads it could be the contacts inside the printer has gone bad. Its suggested by HP that if you get any error regarding the print head you should contact them and they will replace the printer. Please do so. Thanks.
Dec 19, 2011 | HP Officejet 6500 Wireless All-in-One...
HP5500 UV...after paper jam I have a replace lt cyan printhead message and recover black printhead.
The Lt Cyan printhead may have been damaged by the paper jam.
I recommend removing all the printheads and power cycling the machine (turn off then back on) Install the printheads and check that each one says OK. Replace any that show recover or bad. (HP will replace free if it is under warranty - return it to the store you purchased it from)
Nov 15, 2011 | HP DesignJet 5500PS InkJet Printer
My Barcode Printer TSC TTP 244 Plus got problem after printing one line, it got error. I'm using Windows Xp pro SP2 and my setting for printer is Method: Thermal Transfer dan Type: Lables With...
Please check the ribbon installation. The ribbon spindle might have not loaded correctly. You can watch the video clip to verify. http://www.tscprinters.com/cms/upload/download_en/download_232TTP_243_loading_ribbon_E.wmv.wmv
Call TSC Orlando office 407-704-8918 tech support if the problem persists.
Jul 21, 2011 | Computers & Internet
I have Hp Desigejet T1100ps and its showing the error code of 47:01
Description:
Star wheels motor error..
Corrective Action: Try the following:
???? Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
???? Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
???? Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
???? Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
???? Replace the Starwheel Motor → Page 8-167.
???? If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
please rate my answer
i hope this helpfull
Dec 30, 2010 | HP Designjet T1100ps Printer
My router is displaying the following characters when...
HI ,
  • This is due to which IOS u have Uploaded got corrupted or Flash got Corrupted
  • If you are able to go to ROMMON Mode Please upload the IOS through XMODEM Otherwise
  • Please change the FLASH
Sep 25, 2010 | Cisco (1841) Router (cisco1841)
My TSC TTP-245 label printer does not print complete
por fabor necesito las claves de tsc ttp-244 plus pues se me perdieron
May 11, 2009 | Taiwan Semiconductor Co. TSC TTP-243...
Taiwan Semiconductor Co. TSC TTP-243 Thermal Printer Logo
460 people viewed this question
Top Taiwan Semiconductor Co. Office Equipment & Supplies Experts
k24674
Are you a Taiwan Semiconductor Co. Office Equipment and Supply Expert? Answer questions, earn points and help others
