Question about Aiptek A-HD 720P Flash Media Camcorder
Card protect there is a red message thats says card protect and wont let me record
  • 1 more comment
  • snakes1 Apr 01, 2008
    I have the same problem regarding a red card protect screen when I try to take an individual shot or when I try to use the camcorder. Nothing I have tried has solved this issue. In other words my camera is useless!!! I did e-mail the Aiptek technical support and they came back with one solution. Push the switch up on the SD card slot. That did nothing! I have tried to contact Aiptek customer support again and they just blew me off. This is a $250 camera that is worthless.
  • Anonymous Apr 05, 2008
    I am having the exact same problem. I can record just a little bit if I take the SD card out. I have recorded 4 short videos on the 4 GB card, but now I can't record or delete anything. I hope someone can figure this out!! Thanks!
  • Anonymous Jul 26, 2008
    When I record from a TV source, it only lets me record for 17-25 seconds, then says "File Failed" in a big red box. I've tried everything possible but it doesn't seem to want to record any longer. I have a 2g SD card, empty... Any ideas?
For some reason, the SD card in your camera is being viewed as write protected. There is a small "switch" on the SD card that slides. Slide it up and down a few times and try it again. If that does not work, here is the solution that worked for my camera. Place masking tape (opaque, used for painting) over both positions of the switch. I had to put 2 pieces to make it inflexible. Be sure not to get tape on the metal contact points. I hope this works for you. It fixed mine, although I don't really understand why. If this doesn't work, try a new card.
Posted on Apr 05, 2008
  • 37 Answers
You probably need to check the SD card and make sure the "lock" switch isn't pushed down. If it isn't then you may have to format the memory card
Posted on Sep 23, 2008
Test
Posted on Apr 27, 2009
  • Anonymous Apr 27, 2009
    Same problem here (A-HD firmware v1.6), this just occurred
    now for the first time (after using/writing the SD on OS X and Vista), my guess is it must be an issue with the
    "protect" sensing (mechanical?). I tried saraw’s masking tape
    solution and this does at least now allow to again write to SD card (I have a
    2GB). I use one strip only, otherwise the SD gets stuck, so be aware. I also
    tried dance4you’s solution (after masking the protect switch with tape) and
    formatted the SD (connected by USB cable to a XP box) to FAT(16) with the “format”
    command (right click on the external storage device). Removed the tape, alas it
    now worked without the tape, but only once! Same procedure formatting to FAT32
    (nope, still “Card Protect” error), the back to FAT16: Now this does not work
    either. It must have to do with the sensing (cheapo parts), or combination with
    FAT32 writing.
    Bottomline:
    Tape is your helpline here (don’t forget when travelling
    with this cheap little ******).
I had the same problem, and after trying (unsuccessfully) 3 different SDHC card, I finally figured it out.
My camera (A-HD v5v, firmware version 1.600) had a problem supporting FAT32 file system (virtually all SDHC cards would come formatted with this file system), and could only support FAT16 file system.
I've conducted an experiment, by formatting 4 GB SDHC card with FAT16 file system, and using it with camera. It worked (did not get message "Card Protect"), but this procedure will not help with any other SDHC cards, since natural limit for FAT16 file system is 2 GB (absolute limit is 4 GB), and therefore cannot be used with SDHC cards bigger than that. Of course, as soon as I formatted same card with FAT32, I've got the same message - "Card Protect".
Anyhow, solution for this problem is to either:
1. Use only SD cards up to 2 GB size, and formatted with FAT16, or
2. Get updated firmware from Aiptek, which will fix this problem
Unfortunately, #2 is not a clear option, since current available firmware for this camera (2.002) does not list in its Change Log any fix related to above problem. So far, I have not tried new firmware, and therefore I can’t confirm if it will work or not.
Posted on Jun 04, 2008
SOURCE:
Memory card is protected {reset switch on memory Card} ? Go To review
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 26, 2014 | Kodak EasyShare M530 Digital Camera
H4n zoom wont record says card protected
Oct 23, 2013 | Samson Technology Zoom H1 Recording Bundle...
Wont record
Apr 10, 2013 | Coby SNAPP Mini Digital HD 720p...
Mesage "unable to use card"
SD Memory Cards have a write-protect switch to prevent image
data from being deleted. By sliding the switch to the bottom of
the card, the data will be protected. images cannot be recorded
when the card is protected. If an attempt is made to record or
delete an image with the camera, the card-locked message will
appear on the monitor.
Sep 21, 2011 | Konica Minolta DiMAGE Z10 Digital Camera
Reads card protected every time I try to take a picture or record a video.
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Jul 24, 2011 | Cameras
Cant record new video
check the memory card that you've inserted on your camcorder. tilt the protection tab of the memory card to unprotect it.
Jun 29, 2009 | Samsung SC-D372 Camcorder
Dvd recorder has copy protected message
the tapes that you can,t copy are protected, manufacturers used to put a high pitched frequency on the tapes themselves, which would in theory cause a scrambled frequency. the only suggestion i have for you, is to play the tape onto a television, and use a camcorder to record the image from tv to camcorder, then camcorder to pc, and use some good editing software to create the dvd.
alternatively, you could try using a second dvd player, and use your recorder as the second device.
The final but more expensive option, is to look for a way to input the recorder, direct to PC. which you would use picture out, to graphics card input, and the red and white ( Audio ) for the stereo Sound output. does your player or tv have An spdif connection or similar, you may be able to output to camera, rather than to dvd.
Where theres a will, theres a way, but these are a few options.
****Please note:- this information is supplied only as you have the original Movies***
Bear in mind, it is illegal to copy protected content. However as you own the originals, this information is provided to enable you, to backup your Purchased Content.
Thankyou for using fixya.
Mike @ compurepair.
Jun 15, 2009 | JVC DR-MV100B DVD Recorder/VCR
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Locked on card protect
pp.5-6 of your manual has the information on locking/unlocking
Apr 18, 2008 | VuPoint DV-DV1-VP Camcorder
Need an urgent solution regarding "Protection" problem (I have a program to record in next 2 hours) pls pls help !!!
have suddenly getting a "Protection" message in Camera mode. - The viewfinder is OK and i can see the view but a "Protection!" message is blinking in the middle of the screen and the record button is not working if i press
Apr 13, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Aiptek A-HD 720P Flash Media Camcorder Logo
532 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Larry Stiles
Larry Stiles
Ekse
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
