Question about Sony XM-D1000P5 Car Audio Amplifier
Hi, i have a sony XM-D1000P5 and every time i turn the power on it turns on and gives my sub a pulse kind of beat for awhile then it shuts off into protective mode and plays nothing. i don't know what could be wrong. any help guys?
No the sub i have is only 800watts
Posted on May 16, 2010
    Problem Solver:
  • 13 Answers
Speakers are to big for your amp
Posted on May 14, 2010
Can i bridge a Sony Xm-1652Z 2 Channel amp to 2 subs it gives me 2ohms
No - it is not 2 ohm mono stable
  • 1000W max power
  • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
  • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
  • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
  • OTL (Output Transformerless) circuit
  • Pulse power supply
  • Line & High Level Inputs
  • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
  • 80 Hz, -18dB/octave Low Pass Filter Switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Subs womt shut off when car does
sounds like the remote power is not wired properly to shut off when the car does
Dec 04, 2009 | Sony XM-2150GSX Car Audio Amplifier
A pulsin sound from the subs
You don't give us much to go on...
Are your subs self-powered? Disconnect the Line In to see if that makes the pulsing stop. if it does there's some kind of signal coming from UPstream or a cable has poor shielding. If it keeps pulsing something's wrong in the sub's power amp(s).
Isolate that much and come back.
May 12, 2009 | Audio Players & Recorders
Sony XM-D1000P5 in protective mode
Sounds like a wiring short somewhere in the powerline from the battery to the amp. I'm guessing the fuze you're refering to is the one inline from the vehicles' battery to the amp. You'll need to find the short, fix it, then replace any blown fuzes before the amp will power up. Just take your time and go over all the wiring to and from the amp. Make sure the battery power cable hasn't shorted against the firewall(use a rubber grommet here), no screws have gone through it while reinstalling interior panels, and that your amps terminal connections aren't grounding out against each other due to stray copper strands.
Mar 21, 2008 | Sony XM-D1000P5 Car Audio Amplifier
Sony XM-1252GTR Amplifier
Can it power the subs? Yes.
Can it make them crank? Well, that all depends on your expectations. That amp/sub combo is going to give each sub about 125W, which isn't much. But if it's what you have, it's better than nothing. You might also consider using only one sub and bridging the amp. This would put about 340W on the one sub, which is much more reasonable.
Mar 13, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp protection
Hi, Off hand, I believe there is nothing wrong with the setup, maybe just not 100% compatible. It's just that the Sony Amp's protection is doing its job (just too good) and the stock radio is likewise doing it's job (but not too good). Just maybe, at poweron, the stock radio sends out a small burst output (maybe capacitor discharge) that we normally hear as a slight thump in the speakers which was when no Sony amp, ok. However, when you have added the amp, you also amplified the thump, which unfortunately the Sony protection reacts to. You can off course let it be since you have figured out a way to make it work or you can try and install a delay on for the power amp or separate it's power on from the stock stereo. The idea is to turn on the stereo with the Sony off and after a second or less, a manual switch or a delay activated switch will turn on the Sony. The idea is to switch on the Sony after the thump has finished. Good luck and hopes this gives you an idea. Pls post back how things turn up. Kind regards.
Aug 15, 2007 | Sony XM-2002GTR Car Audio Amplifier
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
May 30, 2007 | Sony XM-2002GTR Car Audio Amplifier
Protection mode override
If you have your subs wired to the amp in a bridged configuration, try wiring one to each stereo channel instead. Also, make sure your ground wire is secure and connected to a clean, solid metal part of the vehicle body with the paint scraped off. If this doesn't work, disconnect both subs and try connecting only one at a time; one of the subs may have a problem that is shutting down the amplifier.
Mar 11, 2007 | Sony XM-2002GTR Car Audio Amplifier
Sony XM-D1000P5 Car Audio Amplifier Logo
114 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
