Question about Hoover S2220 Flair Bagless Upright Vacuum
Vacuum motor is not working but the roller is working.
I have a vacuum. Hoover S2220 Flair Bagless Upright Vacuum.
it has two speeds I and II. When i switch to I, it did not turn on at all. when i switch to II, it sounds like only the roller is rotating but the vacuum motor is shut down. what is wrong with this? thanks
reddevil6
  • 1673 Answers
SOURCE: Hoover Flair S2200
Should be the same, Hoover would only have one S2200 model and it doesn't matter who is selling it.
Posted on Jan 29, 2008
SOURCE: hoover u8145-900 savvy upright bagless
me too
Posted on Sep 17, 2008
  • 294 Answers
SOURCE: carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Posted on Jan 17, 2009
buffalonyman
  • 1865 Answers
SOURCE: No manual.
The manual is located here: http://www.hoover.com/pdfs/manuals/U5194900.pdf
Posted on Apr 24, 2009
  • 7 Answers
SOURCE: hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Posted on Aug 06, 2009
How do I replace cogged belt on a hoover s2220?
Make sure its unplugged, flip it onto its front on some paper or cloth. Look at the base moulding and note several small screws hidden down in recesses. Get a Torx or Phillips driver as required and remove them to release the base moulding. Find the damaged roller drive belt, replace and reassemble in reverse order. Take care to ensure the roller and base cover are correctly located otherwise the roller will jamb. If it fluffy inside, take this opportunity to clean it out.
Sep 05, 2014 | Hoover s2220--- vac, flair stick broom...
Attachment of vacuum base to handle
yes friction and the air suction presure keep the head and the handle together.
Jul 25, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
How do I change the belt?
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Jan 22, 2013 | Hoover S2220 Flair Bagless Upright Vacuum
Motor housing is hot
This model has 2 side filters, check and clean those. Be aware that this is a quick clean vac, not to be used for extended periods of time to replace a full size upright. clean the inside filter in the dirt cup.
Apr 16, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
How does the cloth bag attach in the ''Flair bagless Hoover'' ?
take the dirt canister out and it just drops into that and sits flush. then reinstall the canister
Jan 03, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
Carpet setting not working
Jan 12, 2009 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover Flair S2200
Nov 26, 2007 | Vacuums
Hoover S2220 Flair Bagless Upright Vacuum Logo
46 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
