Question about Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
My audio speakers for my tv dont change the volume and i have a reciever hooked on to my tv how can i change the volume?
  • 901 Answers
It looks like sound circuit problem. Contact local service center for assistance.
Posted on May 14, 2010
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
I have 7.1 speakers attached to my receiver, I am using 16 guage wiring and yet I still find the sound in some movies is very inaudible..almost tinny unless I change the audio to 7 channel stereo. My two...
There are a multitude of user settings that can affect the apparent loss of bass you describe. Since you mention it is relevant to a soundfield choice that sort of eliminates hardware problems.
Find the SET Menu and set everything under SOUND according to your actual speaker configuration. For the purposes of set up, consider the word LARGE to mean "CAN handle substantial low bass" and SMALL to mean "would distort or be destroyed by substantial low bass".
Under LFE/Bass Out, the Front/Both setting addresses the sharing (or not) of Low Frequencies with Large Front speakers. I recommend BOTH if your front speakers have large woofers or are otherwise bass-capable (since physical size isn't everything).
Run through the speaker Distance and Level adjustments. The LFE/Level will have a huge effect on perceived bass so check it out.
Check the Dynamic Range. It's vague about what optimim is, but avoid using MIN. I'd try MAX or STD for expected loud listening.
Run Low Freq Test to match the sub to your other speakers.
There are lots of opportunities in this beast for MALadjustment. It's your responsibility to understand the settings you select.
Dec 05, 2009 | Yamaha HTR-5790 Receiver
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
Audio Issue
You may have tried this, but when you hook up audio out from TV to audio in on reciever, did you try the different input options for the reciever. Often times, audio in is an aux1 or aux2 setting on the receiver. If it is working with the DVD player, it is functional, you just have to get the wires hooked up and get the reciever on the correct setting. Also, even if you have TV audio out correctly configured to audio in AND on the correct input setting, the TV volume will have to be UP as well as the receiver volume. NOT ALL THE WAY UP (you'll blow your speakers), but up about 25% for you to hear it.
Jul 29, 2009 | Audio Players & Recorders
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Yamaha v-663 reciever
Most amps will only power two sets of speakers direcrly hooked to amp (A&B). If you want audio throughout the house, I would recommend a PA system set up with individual room volume controls
May 02, 2008 | Audio Players & Recorders
My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No Audio Out to Stereo Reciever
First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
Sep 11, 2007 | Hitachi 51F510 51" Rear Projection...
Sony BRAVIA KDL-52S5100 52 in. LCD HDTV Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
