Question about KitchenAid KSBP25FKSS Side by Side Refrigerator
EVAPERATOR MOTOR WONT START
I CLEANED UP THE MOTOR AREA FREEZER AND REFREGERATOR COMPARTMENT WITH SOAP AND WATER AND THEN RINSED IT ALL DOWN WITH THE WATER HOSE IN DOING SO I LAYED THE BOX FROM ONE SIDE TO THE OTHER SIDE TO MAKE SURE THAT I GOT IT ALL CLEAN AND THEN STOOD IT UP UPRIGHT FOR 24 HOURS BEFOR PLUGING IT IN AND TURNING IT ON THE LIGHTS CAME ON THE FAN MOTOR IN THE MOTOR AREA CAME ON BUT THE EVAPERATOR MOTOR NEVER KICKED ON
mikedurland
  • 481 Answers
SOURCE: GE side by side gss25lsmf stopped working
it could be a number of things but none of them can be fixed without professional help.
things it could be:
  • bad compressor
  • blockage in the freon line
  • small possibility of a freon leak
Posted on Jul 12, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
  • 531 Answers
SOURCE: Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Posted on Apr 02, 2009
localwonder
  • 6784 Answers
SOURCE: Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
Posted on May 24, 2009
  • 653 Answers
SOURCE: Freezer cool but not cold
It sounds like it is due for a shot of freon (or most likely R-134A), and most fridges have a crimped coolant line instead of fittings to connect to for recharging. Call a few refrigerator repair guys and get some quotes, and then compare the price of a new, more energy efficient fridge. You will probably decide you are better off just buying new, considering the average life span of white goods is around 10 years, and no telling what will go bad next.
Posted on Jun 08, 2009
W have a amanda ref model AF12538AEW SER#12987374LX putin to storage a year ago. Worked fine. Pulled it out of storage. Freezer get 34deg. Ref 40 deg. Any thought whats wrong?
THE UNIT HAS MOLD BUILD UP IN THE EVAP COIL IT NEEDS TO BE CLEANED PROPERLY BY REMOVING THE FREEZER RACKS AND THE SCREWS IN THE REAR OF FREEZER COMPARTMENT THEN USE HOT SOAPY WATER IN A SPRAY BOTTLE AND CLEAN THE EVAP COIL AND MAKE SURE THAT THE DRAIN TUBE ISNT CLOGGED REINSTALL PARTS THEN TURN ON BOX CHECK TEMPARATURES. FOOD AND MOLD GETS INTO THE EVAP COIL AND MOVING DOORS AND FLAPS AND AIR PASSAGES CLEAN UNIT WITH HOT WATER AND BLEACH MIXTURE TO KILL MOLD SPRAY OUT ENTIRE BOX WITH MIXTURE OF SOAP AND BLEACH WATER AND RINSE COMPLETELY
May 04, 2015 | Refrigerators
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My refrigerator has water leaking from the freezer into the main refrigerator compartment. How can I stop that?
Ok, you have too sources of water in the freezer section. one from the ice maker if you have one, other is defrost. Either one can cause this, check the drain under the evaporator, most likely the drain is obstructed and the water has no where to exit so it builds up and drains into the lower section (gravity). Te drain can be found under the evaperator behind the false wall in the freezer section. Good Luck
Jan 15, 2015 | Whirlpool Refrigerators
Freezer is working OK (ice cream soft), refrigerator is not working...milk spoiled etc. What to do? Possible self-fixes?
Check under the fridge to assure the coils are clean, if not vacuum and clean with a brush accordingly. While you're down there, make sure the condenser fan motor is turning. Check inside the freezer compartment to make sure the evaperator fan is running.
Jun 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
My dishwasher does not wash the dishes, and all th...
Either:
  1. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller. Disassemble and clean pump if necessary.
  2. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
May 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
We have a bosch she4am dishwasher and just recently the unit doesn't rinse all the soap out of the glasses of the top rack and also a film is being left on the dishes. i have checked the top spinner and it...
check the top of the cabinet after the unit has started to wash the water droplets is the key. if you see water droplets on the very top all over then the unit circulation pump is working. If that checks out then check the jet dry compartment. here is a trick.
open the compartment door, fill compartment until it cant hold anymore liquid,close compartment door,lower and raise the door 3 times,open compartment door check to see if you fill with more jet dry,repeat this process untill it cant take anymore.
what this does is removes the air out of the compartment. this will last for about 10-12 washes. last thing is to turn your faucet water on until it is the hottest then start your machine. use cascade soap and no tablets. when you use tabletrs with jet dry the machine over suds, the rinse aid compartment or dispenser is vidal to drying,cleaning spots and film. hope this helps.
Mar 13, 2010 | Bosch SHE4AM06UC 24 in. Built-in...
My Whirlpool Gold, Quiet model III is not rinsing or drying well. My dishes don't seem clean and there is always diswhashing liquid still in the distribution cup.
the problem that you have is with your water temp not being right to break down the soap and clean your dishes. also you have to fill completely jet dry compartment,very very important for cleaning,drying,and the spots. turn your water on and let it get hot b4 you start the unit . once the water is hot then start the machine. you will see a big difference. send me a 4 thumbs up post if it works
Feb 27, 2010 | Dishwashers
Does it matter what kind of cleaner I use on the Deep Cleaner Model F5821
Yes it does matter which cleaning solution that you use in your steam cleaner. If you use the wrong cleaning solution it may cause problems with the cleaning solution dispensary system. Different steam cleaners use different cleaning solutions. You should always use the steam cleaner solution for your specific cleaner. I have learned this the hard (and expensive) way.
Hard to recommend this but it will work in a pinch. You can use a small amount of liquid laundry detergent diluted with hot water (about 2 table spoons to a gallon) as a stand in for the real deal. DO NOT put the laundry soap solution into the cleaning solution reservoir (the wax content will clog the soap dispensary system). Lightly apply to the area to be shampooed (do not soak). I have used a plastic coffee can with holes poked in the lid like a watering can to apply the soap solution. Use the shampooer to do the scrubbing and remove soapy water from the shampooed area. Fill your soap reservoir with clean hot water. The laundry soap does most of its job during the rinse. Go over the shampooed area with the shampooer moderately soaking the shampooed area to with the hot rinse water. Remove as much of the rinse water as possible. Liquid laundry soap has a high wax content (makes your cloths soft) and if it is not rinsed thoroughly after it is dry the remaining wax will attract dirt faster than the surrounding areas. Other than that it works for a good stand in for the proper detergent in a pinch. As a bonus it smells great.
From what I understand as unorthodox as it is, it works well in small doses, and I don't believe that it causes any damage to the other parts of the steam cleaner as steam cleaners survive drawing up worse things into them than laundry soap.
I hope that you find this helpful
Good Luck!
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
The water doesnt go into the area where the soap is
it only go's into that compartment on the very last rinse,you have,3 compartments .(1,hot )(2 cold)(3 softener)
Sep 03, 2006 | Whirlpool AWM6120 Front Load Washer
Open Questions:
See all KitchenAid KSBP25FKSS Side by Side Refrigerator Questions
KitchenAid KSBP25FKSS Side by Side Refrigerator Logo
37 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
