Question about Technics SL-1200MK2 Turntable
WEAK TO NO SIGNAL ON RCA CABLE - really confusing
I dont really know if this is the problem, but i think my red rca cable has little to no signal at all when i connect it to my serato scratch live. when i scratch forward it doesnt move or just budge a little and if i start playing the record it makes little distorted sounds. but when i scratch backwards everything is fine. i tried switching the rca connectors color coding and now it made my turntable audio scratching forward fine and scratching backward impossible.i tried to give my turntables to a technician and he soldered my RCA's problem but the problem still persists. i tried connecting it to the left deck of the serato and it worked fine but not as good as the signal i got on the right deck.
i tried switching my needles with my other turntable and it works fine so no problem in my needle wiring.
now i dont know where the root problem is, im really confused please help :(
  • romedelarosa May 14, 2010
    insufficient information
    President:
  • 1,851 Answers
You said "i tried switching my needles with my other turntable and it works fine so no problem in my needle wiring" that means that you changed the whole shell (from the end of the tonearm)? I think that your problem is bad fitting of the needle in the cartidge. Also check antiskating and weight.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 14, 2010
  • 5 more comments
  • Stelios
    Stelios May 14, 2010
    What brand - model of stylus do you use?
    Waiting clarification, don't hesitate to post.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
    what i meant was the whole cartridge. not just the needle.
  • Stelios
    Ok, try to remove the needle from the cartridge and plug it again. I believe that it's not fully pluged in and cause these problems. Also check antiskating and weight.
    Thanks and regards
    Stelios
    already did a couple of times bro. and did the old lick the connector posts. lol it dint woek either :( im thinking its the rca cables under the turntables
  • Stelios
    In that case the only solution before changing the cables, is to use a multimeter and measure the resistance between the center and the ring at each RCA connector. It must be the same (I cant be absolute about the value, it depends on the cartridge you use). In the wrong case thereis a problem. I can tell you the way to locate the problem (either cables or cartridge) but can you find and use a multimeter?
    I would suggest you some technician, but you already did that with no luck.
    Thanks and regards
    Stelios
    when i brought my tables to the technician we tested the rca cables for short issues and its working fine using ohmmeter. but im not sure about the rca cable connected beneath my tables if its the root problem. im confused as to where to start but rca cables and carts is an idea..
  • Stelios
    In case you can "co-operate" with the technician I have to suggest this solution:
    Connect the multimeter (ohmmeter) at EACH RCA ends and measure the resistance. With the multimeter connected move slowly - slowly the tonearm all the way (from start to end) to see possible loss of continuity. Check the other RCA (channel) too with the same proccedure. That way you will check the full cable length included the cartridge and the inner cables at the Technics' body.
    In case you want to check just the cables and not the cart, make a temporary short circuit with a piece of cable at each channel's end (at the cart's side) and repeat the above procedure.
    Of course the results should be better if, instead of moving the tonearm by hand, place a record on the platter, place the needle on it and start to spin (don't worry, the multimeter will not be destroyed by the signal)... In this case you will need a lot of patience to keep your eyes on the multimeter...
    Thanks and regards
    Stelios
  • 11,896 Answers
You can test the cable with an ohmmeter in the ohm setting. If it has really good resistance and matches the same as the others, then you could have a failing capaictor on the electrical board.
  • 1 more comment
    earlier this week i also had my electrical board fixed since ive accidentally plugged my 110v turntables to a 220v. so yeah theyve changed my capacitors and do some rewinding. i tried my turntables and it worked fine for a couple of hours and i took a break and unplugged everything, then i came back to do some more music work and when i plugged everything right back in, i started to get the problem. if its my tonearm connection to my needle, my rca connection. technician just fixed my rca and tested it that it has no short issues. some said im getting getting a strong signal on one channel. ive also noticed that the technician didnt cut the rca's in 6". sorry im new to this stuff. please help
  • Nate Stansfield
    Nate Stansfield May 14, 2010
    If the electrical board and rca cables test to be ok, double check your needle, the wiring to the needle and the toner and the arm that is attached to the needle
    would my problem be because of my rca cables beneath my turntables? need to be resoldered? would that make any sense? hmm..
Hooking up dvd player rca type and tv just keeps showing... no signal
Hummmm... the YELLOW RCA should be your VIDEO cable and have VIDEO signals.
Are you SURE your TV is set to the CORRECT "INPUT" SETTING? And DO YOU hear and audio>?
Anthony
Apr 17, 2018 | LG Televison & Video
I have a 52" RCA
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
Feb 17, 2011 | RCA HD61W140 61 in. Rear Projection...
Can't get signal from drc6309 to video/audio input
I dont have a Solution but I have the same problem with my RCA portable dvd DRC6309. I have connected it to three different tv set and I get no Video but I do get Sound through the tv sets... I have sent an e-mail to RCA costemer support hoping for a solution. If I hear anything back I will post it here...
I bought my RCA DRC6309 about a month or two ago at a Wal-mart supercenter. They no longer sell RCA portable dvd players. That is why I contacted RCA directly.
Jul 31, 2009 | RCA DRC6331 Portable DVD Player
Can i hookup extrnal speakers to my hi-fi vcr-dvd recorder without a tuner or a reciver, my model # drc8335. Think you.
I do not think so because the first problem is that the VCR recorder uses RCA audio cables (the White and Red colored cables) but the speakers use regular speaker wire. You cant convert from RCA to regular speaker wire. Second problem is even if you find a way to convert the wires, the DVD recorder does not amplify the sound signal. In fact all DVD players and recorders including VCR combos do NOT amplify the audio signal so you will barely hear it. The receiver does two jobs. First it converts from RCA cable to speaker cable and Second it also amplifies the signal before it sends it out to a speaker. Thats why a receiver is important.
May 01, 2008 | Televison & Video
RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Connecting coaxial cable to dvd-v9700
I was thinking of using the RF modulator box, but in this case, it might not work, since signal should be coming from the cable box. What I dont know if there is a converter for signal from a coaxial cable to an RCA. However, the only way to connect is via RCA.
Sep 06, 2007 | Samsung DVD-V9700
Technics SL-1200MK2 Turntable Logo
306 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
