Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Frezzer is to hot - Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfrezzer is to hot - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 14, 2010
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator top freezer leaks into the bottom refrigerator.
THE DEFROST DRAIN LINE IS CLOGED YOU NEED TO REMOVE PANEL IN FREZZER AND FIND THE DRAIN HOLR MELT ICE AND USE TURKEY BASTER WITH HOT WATER TO CLEAN OUT GLOG
Jan 30, 2010 | Kenmore 64802 Top Freezer Refrigerator
Frezzer coil water is dripping on it
I'm not sure about your icemaker, but i think it should be fine. Simply put, fridges or freezers have to get hot to make themselves cold, and they do drip water from time to time, although usually not a substantial amount. If you want to learn more wiki fridges freezers etc. the water should be an issue unless there are some exposed electrical wires located near it.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frezzer gets hot in side.
You should check and/or replace the defrost timer in your unit, it is located in the rear of the unit toward the bottom. When the unit is hot inside check to see if this timer is activated. You will know if you turn the timer and the unit comes on. Hope this helps.
Mar 27, 2009 | Carrier Beverage-Air Undercounter Freezer...
I forgot my psp on my hot temp. car
Might work if you put in the frezzer for 5 min
Dec 29, 2008 | Sony PlayStation Portable (PSP) Console
Crosley refridgerator
the only probable cause why a freezer compartment will be hot is if the heater coil that used to heat the ice is still running even there are no more ice in the evaporator.
that will only happen if the bi-metal or thermo disc is shorted.
bi metal is a part where in it would open at 4 degress celcius in order for the defrost heater to stop heating. but if it is shorted then even though the evap temp is more than 4 degrees celcius, it is still heating up ang would make the freezer compart,ment hot.
i hope i answered your problems...
pls rate e..
tnx
drcool
Jul 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Frost free frezzer
The drain is probably clogged. Use a pipe cleaner to clear and then use a turkey baster and force hot water through. Follow with a weak bleach solution. Drain is usually in the middle of the bottom. maybe towards the back. It is supposed to drain into a pan underneath the unit and then evaporate. Another solution could be a leaky door gasket. This overwhelms the defrost system and causes leaks.
Jun 16, 2008 | Frigidaire Freezer GLRT183TD
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
