Question about Toshiba Satellite M45-S169 Notebook
How to replace battery on toshiba m45-s169 - Toshiba Satellite M45-S169 Notebook
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
  • Shut down the computer. Disconnect any cords connected to the computer.
  • Turn the computer over.
  • Locate the access door latch.
  • Push down to release the latch, this sets it in the open position, and remove the access door that covers the battery.
  • To replace the access door:
  • Line the access door up with the bottom case and the tabs in the battery bay.
  • Lower battery access door into place.
  • Make sure the toshiba laptop battery is level with the bottom case of your MacBook.
  • Press the latch into place, so it is in the closed position.
  • Posted on May 14, 2010
    5 Suggested Answers
    sparky1500
    • 1066 Answers
    SOURCE: need a driver for a toshiba m45 s169
    here is a link to toshiba's Vista support page, you can search for the proper drivers by model number. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_windows_vista
    Posted on Dec 24, 2008
    • 13 Answers
    SOURCE: forgot password fot toshiba satellite m45-s169
    Thats a Power On Password...I believe the only way that you can get around/reset/disable it...is by taking out the battery out of the Cmos. I will be looking for more ways other then that but thats one that i know works...
    If you would like to attempt it...i dont recommend it for the no computer people...look up fourms and see if others have had the same problem or if people have taken the computer apart and replaced the cmos battery
    Posted on Dec 12, 2009
    SOURCE: I need the M45-S169 manual
    Was just looking for that myself - found the Toshiba manual here. Toshiba's site is useless.
    Posted on Mar 05, 2010
    Testimonial: "great - thanks for the link!"
    etaf
    • 779 Answers
    SOURCE: when i plug in to s-video port on my toshiba
    Change the display settings on the laptop to 800x600 - right click on the desktop > properties > advanced tab You will need to select TV out to enable that function use the FN key and the F5 key together and each time you press it will toggle through an output, not necessarily in this order
    ❖ Built-in display panel only ❖ Built-in display panel and external monitor simultaneously ❖ External monitor only ❖ Built-in display panel and external video device simultaneously (This should be SVideo TV out) ❖ Other external video device only (This should be SVideo TV out)
    Press the FN key and the F5 key 4 times
    On the TV you will need to select the TV input for the S-Video connector - This may be by selecting an Input AV1, AV2, AV3 etc - without the make and model of the TV I cannot say which to select
    Here are some instructions on how to use S-Video - it covers a number of laptops including Toshiba http://www.svideo.com/compaq1700.html
    This is a link to the Toshiba support site for that laptop http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1130627&rpn=PSM43U&modelFilter=M45-S169&selCategory=3&selFamily=1073768663
    Posted on Apr 02, 2010
    Toshiba satellite m45-s169 will not boot windows
    Windows is corrupted or the hard drive has issues, if you have a cd installation disc try a fresh install, if no change! the hardware needs to be checked for possible replacement.
    Apr 14, 2012 | Toshiba Satellite M45-S169 Notebook
    How do I change the CMOS battery in a toshiba Satellite M45-S169 laptop
    open keyboard then check look bettery there
    please click yes for vote
    Jan 15, 2011 | Toshiba Satellite M45-S169 Notebook
    I only had about 30 hours on a Toshiba Satellite M45-S169 laptop when I put it in it's bag about 5 months ago. Recently got it out to use and have no power. Doesn't seem to be the power cord though as...
    take out the battery. plug the AC adapter w/o the battery in. make sure the power outlet is working. you should see a light indcator. test if you can boot it up.
    Hope this helps...
    Sep 08, 2010 | Toshiba Satellite M45-S169 Notebook
    Mar 05, 2010 | Toshiba Satellite M45-S169 Notebook
    Forgot password fot toshiba satellite m45-s169
    Dec 12, 2009 | Toshiba Satellite M45-S165 Notebook
    Satellite M45-S169 - will not POST or power on. Power light comes ON for a few seconds then goes OFF. Power ight cycles ON/OFF six times then stops.
    Hi rich caller i had this problem also with my laptop toshiba satellite M45-S169 and i find solution for this problem..
    Just replaced ram memory and now my laptop works fine hope yours will work too
    please respond if my msg helped you..
    regards
    Bess
    Apr 03, 2009 | Toshiba Satellite M45-S169 Notebook
    No sound driver for my TOSHIBA M45 S169
    go to driverglaxy.com u can get from there
    Jan 29, 2009 | Toshiba (P000352520) Sound Card
    Need a driver for a toshiba m45 s169
    Dec 15, 2008 | Toshiba Satellite M45-S169 Notebook
    I need a mother board for a M45-S169
    laptop mobo's are proprietary, you will have to go through toshiba or a liscensed toshiba repair shop.
    Nov 04, 2008 | Toshiba Satellite M45-S169 Notebook
    Toshiba Satellite M45-S169 Notebook Logo
    218 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
