Question about Sony KDS-R60XBR1 60" Projection HDTV
I hit the on botton and it doesen't come on. I have 4 flashing red lights after the green light stops
Without taking the back cover of the tv off I tried to vacuum the fan through the vent opening, it didn't work. Then I took the hose off of the vacuum and put it on the other side so it would blow out. I blew air into the fan vent and it worked like a charm.
Posted on Jan 22, 2012
  • Sony Master
  • 12,061 Answers
Http://www.scribd.com/doc/16940552/Service-Manual-Kdsr60xbr1
Above is your service manual, perform the troubleshooting steps and you should be able to isolate and troubleshoot, your problem and hopefully effect a repair. Below is another helpfull service and training , manual. http://www.scribd.com/doc/20513612/Sony-Kds-r50xbr1-Kds-r60xbr1-Training-Manual
Posted on May 14, 2010
Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-50A2000 50" HDTV
Cant sync drum kit
after the 4 green lights are flashing you sould just wait for 10 sec and then it shall be connected.
Unless, try to change batteries on the drum kit, and then try again.
Apr 15, 2009 | Activision Guitar Hero III: Legends of...
Won't open or close tries to run but stops
The fault code (4 blinks) is informing you of an issue with the infrared sensor that detects an obstruction in the path of the door.
It is ether misaligned or an issue with the wires leading to it or its faulty.
If the red beam is present at the sending unit (affixed to the doors frame), then it should be aimed at the receiving unit (affixed to the opposite frame) If the beam is received then there should be a green indicator light illuminated.
Good luck
Aduz
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Sharp projector xr10xl standby light flashing and lamp light on what is wrong?
if it's blinking green, nothing is wrong. it's just cooling. if it's blinking red and the lamp is off, the lamp door is open.
Jan 13, 2009 | Sharp XR10XL DLP Projector
Alternate red light blinking of ink and paper botton
saw this on the internet too...
http://www.sscllg.com/epsone.shtml
2. In Configuration tab of the SSC window, select your installed Epson printer and Printer Model
3. Plug-in the printer to your PC and turn the Power On.
4. In your tray, right-click SSC Service Utility, go to Protection Counter, then click Reset Protection Counter.
5. A dialog box will appear, just click Yes.
6. Right-click SSC again in your tray, go to Extra, click Soft Reset. Then say Goodbye to the annoying alternating red & green lights.
Jan 05, 2009 | Office Equipment & Supplies
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Sony KDS-R60XBR1 60" Projection HDTV Logo
417 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
