Question about Corsair Memory (CWC1001003)
Hello, ddr3 ram
I am going to buy 980x today,
there 2 model in that shop
2x4gb 1333 mhz and 4x2gb 1600
i want to know which faster. i have plan to put atleast 16gb
    Genius:
  • 1,354 Answers
Hi
thank you for using Fixya
boss frist of all you have to chack you PC is supporting DDR3 then only you go for new RAM
Posted on May 14, 2010
Does Intel DH61BF motherboard supports 4GB 1600Mhz RAM ?
OK, I was looking for a solution, but hardly got anything that clarify if it's compatible or not. But what I did find out is that if you install a 1600MHz memory stick, this one will clock down to 1333MHz in order for the MB not to crash. Here is a C/P.
Part #: 2xCT102464BA160B • 16GB (2x 8GB Kit) • DDR3-1600 - 1600Mhz - PC3-12800 • CL11 • Dual Rank • Non-ECC • Unbuffered • 1.5V • 16-chip 512Mx8 • Lifetime Advance Replacement Warranty • This 1600 MHz module is programmed to clock down to 1333 / 1066MHz where the system requires it.
Mar 04, 2015 | Intel Computers & Internet
Ram supported for z580/5 5933347 lenovo
The Ideapad z580 series takes DDR3 SODIMMs, either PC3-8500 (1066 MHz) or PC3-10600 (1333 MHZ)
It can go to 4 GB (2 x 2 GB SODIMMs) in 32 bit or 8 GB (2 x 4GB SODIMMs) with a 64 bit OS. Here is the Kingston page, although they have discontinued these models Memory Discontinued Models
Jun 27, 2014 | Computers & Internet
Which is supported ram of transend
motherboards support kind ram ddr3 1333 1600 1866 2133 2400 2600 support 2133 You need to match your motherboard to one of the above clock speeds from your main board manual, some can be safely overclocked, but may fall back to a slower speed based on the cpu speed. for instance ddr 1333 is normal to use, if you use ddr3 1600 or higher the cpu may down clock the ram under certain circumstances such as the load on the cpu running a program. your mb manual should have a page whith all combinations in columns and rows. or go to the mb manufacturing site
Jun 20, 2014 | Intel Motherboard
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
Ram memory does not work in my computer
ram does work in your pc. it works in every pc. Now the type of ram that works is the root of the problem. Basically your looking at 3 types of ram and really only 2 probably unless your pc is a dinosaur. They are DDR II and DDR III Make sure your PC uses the type you purchased. Also, make sure you have the system requirements to run that large of Ram.
Oct 24, 2012 | PNY 8GB Kit 2x4GB PC3-10666 1333 MHz DDR3...
RAM recognized only at 1333 MHz
The Gigabyte website says it only supports up to 1333 DDR3 RAM see her for the spec.
http://www.gigabyte.com/products/product-page.aspx?pid=3645#sp
Mar 14, 2012 | Gigabyte Giga Byte Technology Ultra...
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
My 880GM-E41 motherboard says my Kingston HyperX 8GB (2x4GB) 1600MHz DDR3 Non-ECC CL9 DIMM XMP X2 Grey Series is running at 667 mhz or somthing, but i know it can be overclocked to 1600mhz, how is this...
Rather than '1600' Mhz, it's capable of using DDR (Double Data Rate) RAM at '800' Mhz.
The "double" rate provides 2 bits per cycle, resulting in a rating of 1600 for the RAM.
The RAM that you're currently using is '667', not '800' Mhz, rated.
Buy RAM that is rated at '800'.
May 14, 2011 | MSI 880GME41 AM3 AMD 880G HDMI Micro ATX...
I am planning to have an internet shop n phil.. i would like to know what processor is fitted which has a normal price using ddr3. what motherboard is compatible to this processor.
When you purchase your motherboard, just make sure it says "Socket 939" on the processor detail
If it says Socket 775 or LGA, those are for Intel based processors.
Under the Memory part of the motherboard. It should say DDR2, DDR3 with a MHz such as 1333, 1600, 2000. Both DDR3 and DDR2 are backward compatible with slight speed differences.
Mar 06, 2011 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Computer
If you want a good computer that will last for a good 5 yrs or better purchase a dell computer but make sure its a gaming computer when you do so make sure you have them build it for you max everything out
Mar 13, 2009 | Dell Dimension 3000 PC Desktop
Corsair Memory (CWC1001003) Logo
61 people viewed this question
Top Corsair Memory Computers & Internet Experts
David Payne
David Payne
Are you a Corsair Memory Computer and Internet Expert? Answer questions, earn points and help others
