Question about Nixon Manual NIX0031 Wrist Watch
I cannot replace the watch back on my Perry Ellis watch
I was able to easily remove the back in order to replace the battery but now I cannot get the back on.
  • 714 Answers
A watch press will be needed.
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
American perry ellis how to change battery
Take your Perry Ellis watch to a jeweler to have the battery replaced.
Dec 28, 2017 | Watches
Replacing Watch Backs
some watches are water resistant, and in order to achieve resistance, is made very exact.....
you need to use probably hydraulic press in order to close it back again.... once I had same problem and strenght of my fingers was not enough to close it back.... it just wouldn't pop in.... so only one old guy that used to repair clock had that special small hydraulic press to close lid back....
I hope you understand, I didn't use English to communicate for quite a long time.....
Jan 13, 2014 | Watches
Back has NO screws. How do I easily remove it to replace the two batteries?
Hi, You may know that this watch runs on two batteries, one for digital display and another for analog hands.
If the analog hands stop working all you need to do is to replace the battery and please replace both at the same time since the band and cover take some effort to remove.
You need to take off the both bands first to access the back side than the back cover with a small knife..
Just in case,if you need the user manual here is the link.
Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads .
Take care..
Regards
Jun 14, 2011 | Timex T56381 42 Lap Ironman Triathlon...
I have the Niki Oregon Series watch WA0019-001 and i rplaced the battery myslf because it stopped working. There was difficuly opening the back, and after replacing the battery, the watch will work...
There are sometimes hidden dangers in replacing batteries which is probably why most makers recommend professionals to do the job.
You seem to have had some success but it sounds as if there is an intermittant contact with the battery. If you feel that you can remove the back again, try removing the battery, cleaning it with surgical spirit (to remove any grease that is naturally on fingers) and replace it.
As an engineer, I would expect that a screw on back should go on easily until it reaches the end of travel, when it will tighten. If it is stiff all the way, they you may have crossed the thread and damaged it. Never apply a large force at the start of screing the back on, as the threads are quite fine and may be easily damaged.
If after trying again, you still have the problem, then go to a watch repairer and discuss what you have done and the problem you are having.
Take care.
Good luck.
Feb 10, 2011 | Nike Oregon Series WA0019-001 Wrist Watch
Battery is gone (I think) and regular watch repair places don't fix it (need a special tool to open it)
does it have a slot on the back ? usually Nike watches are made to easily replace the battery usually with a nickle slot on the back or screws on the corners. The batteries they have are usually common 2806 or similar coin sized batteries. It will say on the back of the battery .
Most jewelry or watch repair shops can easily replace these batteries. if you bought the watch within a year , have receipt and something is broken. You can send it back to nike to be repair for free. It is done by parsec located here http://www.nikewatchrepair.com/.
Oct 14, 2010 | Nike WC0021 001 Mettle Hammer watch
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Remove the back, to replace the battery
    You need either a caseback knife or caseback wrench depending on whether it's a screwdown or snap-on back. If it's a snap-on, you'll also need a caseback presser to put it back on. Using the wrong tools can easily cause damage to your watch. If the watch is "water-resistant" be sure to replace the gasket as well or it will leak - you cannot reuse the gasket. You best bet to do this without having to buy tools, find the correct battery and gasket and risking scratching the watch is to let a watch shop or jeweler do it. Most places will charge about $8 to replace the battery and gasket. Sears sometimes charges only $4 so either way it's worth it. Even though I have the tools myself I usually bring my watches in and have it done since I'd have to go out and buy the battery & gasket anyway.
    Apr 23, 2010 | Columbia All Sport Digital watch
    How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
    You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
    Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
    I can't seem to remove the back casing on my Bulova watch in order to replace the battery.
    If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
    Oct 25, 2008 | Bulova Watches
    Changing a watch battery
    I used a sharp penknife blade to remove the watch front by getting right on the base and pinching the glass off, (comes off quite easily) tilt the watch out of the case and see enough to prise battery out with a needle. The battery is a Maxwell SR920W or equivalent. Have ordered new batteries on ebay.
    Oct 04, 2007 | Watches
    Nixon Manual NIX0031 Wrist Watch Logo
    567 people viewed this question
    Top Nixon Watches Experts
    Ansel Alberto
    Ansel Alberto
    rhodesworks
    Are you a Nixon Watch Expert? Answer questions, earn points and help others
