Question about Refrigerators
Want to know if my fridge has been recalled.......model number mabb2224des........the fridge part is no longer running, the bottom freezer seems to be fine tho......
    President:
  • Refrigerators Master
  • 2,651 Answers
Did you mean ABB2224DES, unabve to locate an MABB2224DES. adn if so ther is no current recall outher , at least not one that im aware of ,and im an authorized servicer for maytag/amana.
Posted on Mar 30, 2008
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
My whirlpool side by side stainless fridge is not freezing 2009 model what can i do? Is this a recall or a common problem for a new fridge?
first off open the fridge door,up on the right hand side near the ceiling send the model number.also when you open the freezer door do you hear the fan blowing?if so from the bottom up remove the second bin and touch the back inside wall of the freezer,is there ice or like snow on it,if so you have a defrost problem,let me know what you find and send the model number.
Apr 24, 2011 | Refrigerators
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
I have a bottom freezer refrigerator and the freezer works but the fridge does not,,condensation forms on bottom of fridge. What is going on?
Check in the inside rear of the refrigerator cabinet for vents.When you hear the compressor running, wet your fingers and hold them in frontof the vent to check for air flow.
If it seems there is none, then the fan that is supposed to distribute the coldair from the freezer is no longer running.
If this is true, go to the Sears parts department and enter makeand model number to see if they have a line drawing illustration of your unit.
This will allow you to see if this fan is accessible enough for youto DIY or if you need a pro.
Sears partsdepartment
Good luck-
Jun 19, 2010 | GE Profile PDS22MHR Bottom Freezer...
I have a Kenmore bottom fridge model #596.69274991. Although things are cold and frozen, the room temp is only 70 degree but it seem to run for well over an hour although there has not been much opening...
Tom, you pretty much have it all covered. Make sure both the freezer fan and the fan under the fridge are both running and keep your eye on the inside back wall of the freezer compartment fro any signs of frost build up (possible defrost problem).
Jun 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Jun 19, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Freezer does not work
Most model numbers are located in places like the photo shows below. It may be the thermostat itself causing the problem with freezer, yet I don't believe I have seen a refrigerator running without using the freezer to cool the refrigerator section. I guess anythings possible. Let me know, Thanks, Sea Breeze
Apr 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
