Question about Nordic Track NordicTrack A2750 PRO Treadmill
How do you adjust or tighten the belt on the Nordic Track A2750 The belt is riding to one side of the platform
    President:
  • Nordic Track Master
  • 832 Answers
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
Posted on May 14, 2010
Belt is loose
there are adjustment bolts on the back end of the treadmill. they are on either side. start with belt running about 3mph. tighten the side where the belt is closest. about 1/4 turn. give 15-20 seconds to see adjustment . when it is centered, tighten both bolts evenly until belt is tight.
Apr 19, 2014 | Nordic Track NordicTrack A2550 PRO...
Belt stops when stepped on
sounds like the belt is loose.there are bolts at the back on either side that tighten or loosen the belt.adjust with belt running about 3mph. tighten both bolts about 1/4 turn each while watching the belt to make sure it is centered. give it about 15 seconds after you tighten to see the adjustment that u make.the walking belt should only be able to lift up a little bit like 1 inch. you shouldn't be able to get ur hand all the way under belt (not running of course).
Apr 09, 2014 | Nordic Track NordicTrack A2750 Pro...
Belt off center on front roller
see the video and proceed according. God bless you
Jul 19, 2013 | Nordic Track NordicTrack A2750 PRO...
Belt off center
see the video and proceed. God bless you
Hello, my Nordic Track A2750 will not power up the console. I assumed I burned out the console, replaced it, but still will not power up. Power was verified at the outlet and the back side of the switch?...
1) adjust the REED switch , see the diagram, clean it and tight
the plug very well
2)test the fuse+ c.breaker see the diagram , replace or reset
2a) test the main switch for open or faulty and replace
3) if after this the problem remain.
4) you have problem with the power supply:capacitor, transformer, diodes,etc Replace the main boad
see the block diagram
God bless you
Sep 25, 2012 | Nordic Track Exercise & Fitness
I hear a squeezing noise coming from the front of the treadmill when I run. Every time I land on the platform it squeeks.
take hood off and check the front roller. you mite have to take the side foot rail off to view the roller
Mar 04, 2011 | Nordic Track NordicTrack A2750 PRO...
When you have adjusted the most you can, should you replace the belt?
If you have tightened the belt and it continues to slip it is usually a sign that the deck and belt are worn. You may be looking at repairs that might be more costly than getting a new machine. You can check the deck by sliding your hand under the belt (not running) and feeling the deck surface. If you feel grooves or any rough spots then you need to replace it. The underside of the walking belt will also feel fuzzy like a peach if the fibers are breaking down.
If the machine is not very old or hasnt had much use then it could be several other things causing the slipping/stopping of the belt.
Feb 24, 2011 | Nordic Track NordicTrack A2750 PRO...
The belt is tracking to the right side. I tried to adjust it using the hex key, but that seemed to make it worse. Also, when running, the seems to stop or jar under my feet. The motor makes a whining...
It sounds like you have a bad bearing. If you are not familiar with repairing/replacing bearings on a treadmill, I suggest you contact NordicTrak and have a tech come out and repair it.
Jan 06, 2011 | Nordic Track NordicTrack A2750 PRO...
Belt will not stay tight.
Is it slipping side-to-side or front-to-back? If side to side, you can stop this by adjusting the two allen bolts on the bottom fronts sides of the treadmill. If it is front to front, and your treadmill is more than a few years old, the belt is probably stretched and needs replacing.
You can get a quote for a new belt at treadmill parts
Dec 19, 2010 | Nordic Track NordicTrack A2750 PRO...
How to adjust the running belt??
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
belt is properly tightened."
Dec 18, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack A2750 PRO Treadmill Logo
1,224 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
