Question about Canon PowerShot SD790 IS Digital Camera
It cant read the memory car, the memory card slot is too tight memory card can't be fitted!and when i put the memory card on the slot of the camera and on it it always say memory card lock! how could i fix this? is there any solution for this?
    Brigadier General:
  • 11,967 Answers
Sounds like two things are happening here. You may be putting the card in improperly...check the manual to see if the card should be face up or face down. Also, be sure the slide switch on the side of the card is in the unlocked position.
Posted on May 14, 2010
Canon digial camera power shot SD430 says memory card error when switching on after putting new card in.
What type and size memory card? The SD430 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards even though they will fit into the slot.
Mar 05, 2013 | Canon PowerShot SD430 / Digital IXUS...
I`ve bought a 4GB memory SDHC memory card to my Canon powershot A 430 camera, and when i put it in my camera - it says memory card error. I tried to unlock it by the small button, but didin`t help. What...
The Canon A430 uses MMC and SD cards. While SDHC cards will fit into the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Dec 24, 2010 | Canon PowerShot A430 Digital Camera
How much memory can be expanded to maximum in canon sd790??rushab
You can expand the memory as much as you want. The SD790 uses SD and SDHC cards, which go up to 32GB each. You can swap cards in and out, as many as you want. However, I would strongly suggest you transfer the pictures to your computer on a regular basis instead of storing them on your camera and/or memory card.
Dec 04, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
How do you access the internal memory on a canon power shot sd790is?
The internal memory can not be accessed, you can only access the memory card that holds the photos and this done by connecting the USB cable between the camera and PC.
Oct 01, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
I leave tomorrow HELP I have a Canon Powershot A530 and when I put in an 4GM memory card I get Memory Card Error
The A530 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it won't work there. You need to go with SD cards 2GB and smaller.
Sep 28, 2010 | Canon PowerShot A530 Digital Camera
Memory card is locked for Cannon Power Shot SD790 - how can I fix the problem?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Sep 06, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Got memory full on cannon powers hot sd790 is what do i do?
just copy all the photos form the memory card to a computer, then delete all the pictures form the card. u'll be able to click pictures again. connect the camera to the PC via USB or just connect the memory card
Apr 20, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
My Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Sep 12, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
How do i upload my video from my Canon PowerShot sd 790is camera on to my Sony Vaio laptop?
If you have your video stored on a memory card that is in your camera then get yourself a memory card reader. This will plug into your computer. Put the memory card into the reader and you should be able to copy & paste your video onto your computer. The card reader can be purchased fro about $20 from any store that sells cameras or similar items.
Hope this helps.
Jul 24, 2009 | Canon PowerShot SD790 IS Digital Camera
Canon PowerShot SD790 IS Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
