PROLINE WASHING MACHINE W1000
The water pump did have water in it,letting pump dry out gonna try washer tomorrow i live in Chepstow i have been looking for another pump just in case it does not work.
    Sergeant:
  • 351 Answers
I live in australia.i dont think it will be the pump but i could be wrong.
Posted on Apr 01, 2008
MACHINE STOPS RIGHT AT RINSE AND SPIN CYCLE. DIGITAL READING SAYS 21-F OR 5-D.
unplug the washer,remove the bottom panel,with a shop vac,vac out all the water in the tub,next put down some towels on the floor and around the pump and have the shop vac ready,unscrew the middle part of the pump just enough to have water draining out and vac it up as it's coming out with your vac,when all the water is drained remove the middle part of the pump and clean it out,don't get surprized from what you're gonna find in there and the water is gonna be stinky.put the pump back together,add some water to the washer and then hit spin,you should hear the water draining out,if it doesn't you still have something in the pump or you killed the pump and need to change out the pump with a new one,also check the hose that connects to the pump,stuff gets stuck in the hose,you should be fine,let me know what you find in there and how you make out
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My AEG lavamat 74620 doesnt fill up with water
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
May 06, 2009 | AEG Lavamat 72640 Front Load Washer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
May 08, 2008 | AEG L86800 Front Load Washer
AEG Lavamat 86720 washing machine fault code C3 with buzzer and pre-wash and main wash lights flashing
post further comment for more help......
May 05, 2008 | AEG L86800 Front Load Washer
Water won't stay in washer ...
either the pump is broken or the drainhose is lose or too low.
There is also in this machine something called a drain protector. This might be faulty too and i think that would be the cheapest to see about that first
LINK for the water drain including all parts
LINK for all machine parts motor and pump
May 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
AEG LAV86741 washing machine
hi,
post comment for more help...
good luck.....
Apr 21, 2008 | AEG L86800 Front Load Washer
Proline W1000 washing machine
most times you can fit a generic brand pump,take it with you when you buy another one.where do you live i may be able to help.ps was the pump leaking and causing it to trip the power.
Mar 29, 2008 | Washing Machines
Proline W1000 washing machine keeps on triping main electrical switch
check for water leaks,unplug heating element,and try again.or the motor,then try again.
Mar 28, 2008 | Beko 24 in. D3421F Free-standing...
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
