Question about HP Compaq Presario V2000 Notebook
Hello, I have a compaq presario v2000 and when I turn it on it goes through the normal start up until it gets to the point of going to the sign in mode. Then it goes to a solid blue screen with white letters for only a second or two, then it goes to which way would I like to boot the computer through safe mode etcetera, and does this over and over
    Genius:
  • HP Master
  • 1,354 Answers
HI
thank you for using Fixya
i would like to inform that your problem is indicates 2 isuue
1 your Windows is not working properly repair windows if know that how to repair
2 RAM is not supporting
frist try to replace your RAM then Try to on hope fully it will work normaly
Posted on May 14, 2010
Who to install compaq presario v2000 sound driver for xp
go to the following steps//
start/ right click my computer/ properties/hardware/ device manager/
window of device manager will open and then click the + sign of sound // driver will be highlighted// right click and then select uninstall// after that is done then restart the computer// sound driver will get install automatically//
also you can go to www.hp.com select support and driver// select the operating system as XP and then download the driver..run the same to install successfully//
Jul 06, 2010 | HP Compaq Presario V2000 Notebook
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Where can i get free sound driver for compaq presario v2000
sign up at www.driverguide.com its free and search there , ive been a member there for years,they have every driver you can think of
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presaro V2000 will not power on after mini-pci card removed
HELLO,PRESS AND HOLD THE POWER ON BUTTON FOR A FEW SECONDS UNTIL YOU GET A POWER LIGHT.ONCE YOU GET THE LIGHT,THE LAPTOP SHOULD BOOT UP NORMALLY.IF THAT DOESNT WORK,REMOVE THE BATTERY AND TRY TO POWER UP WITH JUST THE AC ADAPTER PLUGGED IN.ONCE YOU GET BOOTED,INSTALL THE BROADCOM WIRELESS CARD SOFTWARE FIRST FROM THE CD THAT CAME WITH THE ADAPTER.THE SET-UP WILL THEN ASK YOU TO INSTALL THE CARD AFTER THE DRIVERS HAVE BEEN LOADED.YOU SHOULD BE ABLE TO GET ONLINE ONCE ALL THE STEPS HAVE BEEN COMPLETED.GOOD LUCK
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
Startup problem
This is generally an indication of a hard drive failure. You will most likely have to replace the hard drive.
Jul 23, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
