Question about Dell W3201C 32 in. LCD Television
Dell 32in LCD-picture ok. but no sound
Tested speakers with stereo receiver. they worked fine. Can anyone help me? Please
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, 2 possibilities:
  • setting / configuration - is the MUTE engaged?
  • hardware fault - is the volume level displayed when VOLUME is pressed UP/DOWN. Are the speaker wires correctly installed to the speaker terminals?
Offhand on a Dell W3201C, check the AUDIO SETTINGS / menu and confirm that the settings for the:
  • PROGRAM is set to STEREO not SAP;
  • SPEAKER is set to ON.
Should the above be not corrective, options then are:
  • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center or a qualified professional.
Good luck and thank you for asking FixYa.
Posted on May 14, 2010
The sound on my tv is just clicking
First, try to connect ext speakers. If the sound is OK just replace speakers. Otherwise the problem in amped sound output.
Feb 09, 2015 | Samsung HLN567W 56" Rear Projection HDTV
Bought the stereo 6 months ago, now the speakers won't work!!!! Please help!
Hi, when a speaker does not work, you might need to do some troubleshooting tips to know exactly where the problem is .
First you will need to test the speaker cone if it's working properly by using an AA battery and two wires to make sure the cone is working..
Connect one of the wires to the Positive side of the speaker, and the other on the Negative side, And after that use the battery to hear if the speaker cone will make a click sound.
If it doesn't make a click, that means the speaker cone is Bad, you will need to replace the speaker cone,
But if there is click from the speaker cone, that means the speaker is Ok, and you might need to trouble shoot your stereo to be sure if the sound IC chip is Ok in the stereo..
Hope it helped..
Aug 10, 2011 | Audio Players & Recorders
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Apr 19, 2011 | NAD T763 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Harman Kardon AVR 500 Only works in NON-Surff mode ?
This is a good indication that the surround processing section has a problem. This can be anything from a supply voltage being missing to a defective processing IC. Without testing inside the unit, it wil be difficult to determine. With surround procesing turned off, the entire section is bypassed. This is why standard stereo mode sounds OK. The static sound is digital noise and can be poor processing or a bad D/A converter IC.
Hope this helps,
Dan
Feb 26, 2010 | Harman Kardon AVR 500 Receiver
I would really hope someone would its a dell LCD issue :(
you can contact dell and ask or google it to see if anyone else has experienced your problem.
Jan 04, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My Dell 32in. LCD TV, model W3201C no longer produces any sound.
That was indeed the sound module. I spent hours trying to find a replacement for my Dell TV. There was one on eBay for over $100.00, I decided to remove my speakers and install a low cost sound bar from Radio Shack. Easy to install and sounds fine. Several techs told me those boards are a problem along with every other board in those sets and since the Dell is low quality to begin with, I wouldn't spend the money. Go with the sound bar and buy a real TV next time. I'll go Samsung or Sony when mine finally dies for good.
Mar 31, 2009 | Dell W3201C 32 in. LCD Television
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
ILo 32in 3206
With remote control click TV Menu, scroll down to "Sound" click right toggle arrow, scroll down again to "Speaker" and make sure it is set to "Internal" if useing TV speakers or "External" if routing sound output to a stereo or surround system.
May 27, 2007 | iLO 3200 32 in. LCD Television
Dell W3201C 32 in. LCD Television Logo
122 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
