My ISP is AOL currently, I wanted to know if its posssible to have a static and dynamic ip address at home with different networks that you can manually connect to? I want to keep my computer safe from hackers trying to access my bank information by having a dynamic IP, but I want to be able to use my bulk email program efficiently by having a static IP and send out emails in bulk, and have messages get delivered credibly Any advice help or where to go for this scenario is appreciated
  • 4,924 Answers
This you have to establish with the provider...the ISP is the one that assign you an Ip address in both cases..and for to have a static Ip probably have to provide the Mac address for them ..and for the other option you have to just tell them that you want one ..that is not static and will actually change probably once a day or each time you connect (open ) the PC ..
If I were you ..and to make this as efficient is possible I will install a second network card in my computer ...and ask the ISP to get me a second line (in the same contract ) But with a dynamic Ip address. .this will provide you a quick switch from one to the other ..without being forced to change cables or anything else..and make your bulk mail work perfect when is connected to the static ..and be a moving target when you are on dynamic...and all you have to do is access one connection or the other from My network places in the computer ...and enable one and disable the other ...just a couple of clicks..
I can not see any other way ..by maybe using a router ..and set it with a large ip range ..and force it somehow to change the ip periodically ..and you will actually use the static Ip and settings in the wlan (router connection with the ISP... and have a dynamic on the internal ...network ...but Im not sure how can be done (depends on the router model) and probably its much complicated and expensive than the first one ...So ...call your provider for a dynamic second line ...get a second pci Lan card ..and go to it ..its the easiest way ..
also you can ask the ISP..if you can keep in working the bulk email ....and run a dynamic Ip from them ...in this case all the changes will be from the static to dynamic and problem is solved with no extra costs..cause the dynamic one is usually cheaper than the static..
if the ISP only provide the static IP ...keep it ...and make a second line on other provider and use them like I said with 2 LAN card s...in parallel..
Posted on May 14, 2010
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
192.168.0.13
77.248.24.119 is the dns from the internet service provider
192.168.0.13 is the router address
Jul 07, 2015 | Computers & Internet
Change ip address
Is your ip is static or dynamic?If it is dynamic,then you have to reset your modem or else if it is static,then ask your ISP to change your ip.To know your network ip address visit Ip-Details.com .
Apr 07, 2013 | D-Link DCS-6620 Internet Camera
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
Home > Wizard
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Dec 08, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
