Question about Exercise & Fitness
Display gets blank when running - Exercise & Fitness
  • John Mazmanian
    John Mazmanian May 14, 2010
    Does the entire unit shut down and stop or just display won't show functions
  • mariocanda May 14, 2010
    everything runs fine, just the display gets blank after few minutes working, but no other problem. The machine is only 4 month old.
    President:
  • 832 Answers
If you install this unit then I suggest that you unplug unit then remove motor shroud and inspect the lower board connection then, remove the upper console check all connections. If you are able or someone else can plug in unit then start it without walking see if the display blanks out in those 4 mins then if it does then tap on the console to see if the display will show the functions.If not call the place that you purchased the unit or call the manufacturer directly you they should send you another display.
Posted on May 14, 2010
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
Lexmark C534dn has a blank display and a red light. How do I get the display back and a green ready light?
If display is blank you likely have a bad display or some other problem that will require replacements parts. Keep in mind that on Lexmarks the control panels are keyed to the formatter so you cannot just get a used panel from another printer, you must purchase a new one.
Sep 03, 2014 | Lexmark C534dn Color Laser Printer
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Why my watch not display or blank after keep for long time
As this is a solar powered watch,there is the PS (Power Saver) function.
If PS is ON (which is by default) display will become blank if watch stays in the dark for sometime.As you bring it back in light,display will be activated automatically.You can switch PS to OFF and have display activated all the time even in dark (not recommended) but in this case battery will run short quickly.And this watch needs power as it is a multifunction watch + atomic time setting.
Nov 10, 2013 | Casio PRG-130T-7VDR PRG-130-7 Protrek...
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
No response from player
Go to www.usasupport.philips.com to get the Device Manager for this player - run a repair.
May 23, 2008 | Philips HDD1630 MP3 Player
Monitor goes blank if run from battery
From the mains?
You mean power?
If you have to uninstall the display controller , that means that your video drivers are bad, and you are running the native video drivers.
Get new updated drivers and keep us posted.
Nov 17, 2007 | HP Pavilion dv4000 Notebook
Exercise & Fitness Logo
78 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
