Question about Bulova Wittnauer Krystal Collection 12A02 Watch for Men
Can't get the back cover on after replacing batteryin a wittnauer sapphire crystal ladies and mens watch what's the trick?
    President:
  • 2,501 Answers
I have not seen your watch but am I right in guessing that theback was prized off?
If that is so, you might be able to get it back on by holding against a flat surface and press the back with both thumbs at one point and then slide your thumbs away from each other until they meet at the far side.
You must keep a firm pressure on the back at all times.
If this does not work, I suggest you take it to a watch shop! Good luck and have patience, it is likely too take several attempts to get it on.
Posted on May 15, 2010
Replace wittnauer wrist watch band
Looking for men's Wittnauer gold stainless watch band for JV 8243 Swiss 9544.
Please advise if you know where the are available.
Regards,
Steven Foxworth
sfoxworth1@comcast.net
Apr 10, 2012 | Wittnauer 10D02 Montserrat Watch for Men
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
The winding stem is broken can this be repaired?
It is possible to repair this but it probably needs to go back to the maker.
To locate your nearest service center go to http://www.bulova.com/brands/wittnauer/wittnauer.aspx?brand=wittnauer and click on "service center" at the head of the page.
Dec 22, 2010 | Wittnauer Astor Collection Multi Tone...
Ladies Ebel wave w/diamonds and sapphire face............jeweler cannot replace battery, does crystal need to be removed or remove back?
The back will need to be romoved, but in doing so yourself, you will VOID your warranty, and since this is an expensive watch, I highly recommend that you send it in.
You can find all this information here:
http://service.movadogroup.com/faq.cfm#127
Best regards.
Aug 23, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: I like it so much, ...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Guest,
Please feel free to browse above link for the prices of your dream watch.
Thank you.
May 18, 2010 | Tissot T Touch Stainlesssteel Watch
Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: Very interesting sites., ...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Please feel free to browse above link for your desired watches.
Thank you.
May 17, 2010 | Tissot T Touch Stainlesssteel Watch
I have a ladies Philip Stein, w, double movement. Tried to buff crystal. Now neither movement is working. Batteries are OK
If the stems are in the time positon and the batteries are ok what probably happened is extreme heat. You tried to polish a mineral crystal and it got hot. The only type of crystal you can polish is acrylic. Most of these models come with mineral crystal or scratch proof sapphire crystal. I recommend going to a watch maker/technician and having the movements replaced. A reputable watch maker/technician will be pretty reasonable.
Sep 19, 2009 | Philip Stein Teslar Small Case Diamond...
Bulova Wittnauer Krystal Collection 12A02 Watch for Men Logo
124 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
