Question about Home
I have excess mineral depsoits (white, chaslky scaling). Whaty chemical do I use to dissolve it ?
    New Friend:
  • 4 Answers
Try lidl dishwasher tablets, cleand deep scale deposits in my toilet
Posted on Dec 31, 2014
    Scholar:
  • 102 Answers
Vinegar will help loosen up the minerals. If problem is bad then muratin acid will work. COUTION muratic acid can be purchased at your local hardware store and is used for cleaning concrete, but can be very dangerous. It does however eat through hard water deposits. It will emit fumes while working so be sure to ventilate and it can discolor colored porcelin. We have used it in the trade for many years to acid clean toilets. Hope this helps.
Posted on May 14, 2010
I want to know best way to clean the humidifier and how often?
It all depends on a couple of factors.
First is the type of humidifier your using. Portable or whole house connected to the furnace. Steam, ultrasonic or filter. Your unit's instructions is the best guide as to how often you need to clean it and this can vary from every day to once a heating season.
My recommendation is to watch and clean the unit as soon as you see scale forming. Then in the future, reduce this to just before you see scale forming.
The second is the type of water you are using. Hard tap water is the worst and usually will require every day for small portable steam or ultrasonic units to once a week for filter models. For central whole house humidifiers, once a month (perhaps as little as every two weeks if your water is really hard, >10 grains hardness). There is no fixed formula for this, the idea is to perform on-going, preventive maintenance.
Soft or conditioned water will contain the same amount of minerals as hard, but the softener has replaced the calcium minerals with sodium minerals. (Sodium bicarbonate actually).The result is the humidifier will still form scale but it much easier to remove. With soft water scale, you can just break up the scale with your fingers and the filters can just be submerged in clean water and the salt scale will re-dissolve.
Third, with distilled water, you may only need to clean any of these units annually. (No minerals to for scale).
With any filter humidifier, consider using a commercial bactericide to prevent the growth of bacteria when the water sits for long periods (>14 days). Not so critical with soft water as the salt will retard the growth of bacteria, but very important with hard or distilled water. Don't use this product in ultrasonic or steam humidifiers as it will be carried into the air along with the water vapor, and can be considered as toxic.
With hard water, use a 50/50 solution of white vinegar and water to dissolve the scale buildup. This works best if done on a regular basis. If left go too long, it become impossible to clean properly. You need only use regular water when using soft or distilled water in your humidifier.
Dec 25, 2015 | Kenmore Cool-Mist Ultrasonic Humidifier...
Machine is clogged and water will not drip through to make espresso. the steam frother works sort of
Did your User Manual have a section that tells you how to clean out mineral deposits and hard water scale? Usually, this is done by filling the resevoir with white vinegar and then turning the machine ON for 30 seconds then OFF for 5 minutes. Keep repeating the ON-OFF cleaning cycle until all the vinegar is pumped into the carafe. If the machine needs further cleaning. Repeat the process until the scale and mineral deposits are dissolved. Finally, flush the machine with a full resevoir of clean water and run a normal BREW cycle. Should work like new.
Apr 25, 2015 | Mr. Coffee ECM20 Espresso Machine
My Mr. Coffee BVMC-SJX33GT 12-Cup Programmable Coffeemaker, Chrome is not circulating water properly. only half of the coffee grinds get reached by water for brewing. How can i fix this?
Clean the hard water scale and mineral depsosits with vinegar. Fill resvoir with white vinegar. 30 seconds ON, 5 minutes OFF, repeat until resevoir is empty. Repeat the process until all the deposits are dissolved. Should work like new.
Dec 19, 2014 | Mr. Coffee Coffee Makers & Espresso...
What does de-scale mean?
To de-scale anything in relation to water means to remove the mineral scale buildup on the walls or where ever. That's the usually white chalky stuff that you might see around nozzles etc. Follow yu manuals instructions to de-scale. Usually involving white vinegar, or possibly a product like CLR for removing minerals and rust stains. I AM NOT SAYING TO USE CLR IN YOUR MACHINE, just indicating an example of a product that manages mineral scale. Read the manual to do it correctly.
Nov 26, 2010 | Keurig B100 Coffee Maker
Glasses have a film when dishwasher is done.
There are several things that could cause this; 1. The rinse agent dispenser is out of rinse agent(Jet Dry). 2. The dispenser is not working and is easy to replace by removing the four screws that hold the door panel on and the two that removes the dispenser(be sure the breaker is turned-off). 3. The water temperature coming into the unit from the water-heater is not hot enough. 4.Your water may need to be tested for excessive minerals or chemicals. 5. Low grade detergent may not dissolve correctly.
Jul 28, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
It's blinking de-scale side water holder gets r4eally hot water is not coming out properlywhen u press one of the cup size bottons
This is the time, you need to Descale the machine. The simple procedure is :-
Unfortunately, in spite of the best-laid plans of mice and men, espresso machines often get clogged by scale, deposits of minerals from hard water. Scale can cause serious damage if untreated. If your espresso machine's water flow has decreased a lot, it's probably because of scale. Fortunately, there is an easy and inexpensive way to descale your espresso machine.
  1. Obtain some citric acid. You can either order this online or find it in the kosher foods section of the supermarket (usually marketed as "sour salt"). Acid solutions dissolve scale, which is made of calcium carbonate. There are special solutions marketed specifically for descaling, but citric acid works just as well and is much cheaper.
  2. Prepare the descaling solution by mixing citric acid with water (I use two tablespoons of acid and a quart of water).
  3. Put the descaling solution in the water tank, turn on the machine, and run water through the steam wand until the cup is filled, to expose the parts to the solution. Turn off the machine, and leave it for 20 minutes so that the solution has time to dissolve scale.
  4. After 20 minutes, run more water
  5. Run solution through the machine every 20 minutes, until the water tank is empty.
  6. Fill the water tank with plain water, and run water through the machine until output water no longer tastes sour. This is important, because excess citric acid does not make coffee taste good.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 12, 2009 | Keurig Coffee Makers & Espresso Machines
How do I clean the heating elements in my swan tea kettle. it looks like a mineral build up on the elements that comes off when the element is hot and the minerals fall into my tea water
IF THE BUILD UP OF SCALE IS BAD YOU MAY HAVE TO TREAT SEVERAL TIMES TO CLEAN. VINIGER IS A GOOD CHOICE, JUST FILL ABOVE THE COILS AND LET SIT AND DO THIS AS MANY TIMES AS IT TAKES TO CLEAN THE COILS. ANOTHER GOOD PRODUCT IS CALLED- CLR MOST HOME DEPOTS HANDLE THIS PRODUCT IT STANDS FOR C-CALSIUM / L- LIME / R- RUST
THIS IS A LITTLE STRONGER THEN VINIGER BUT DOES THE SAME THING. BOTH WILL TAKE SEVERAL CLEANINGS
Sep 05, 2009 | Swan Kitchen Appliances - Others
Camera fell into water. removed housing and dried parts, camera doesnt work now and batteries get extremely HOT!!!
only chance is specialist electronic cleaning or you can try yourself with molar acetone (ie chemically pure, not nail polish remover which contains lanolin). Tap, rain or bottled water contains dissolved minerals which are deposited on wherever the water happens to lie. It is these minerals that conduct electricity (pure H2O does not conduct electricity) and it is these impurities that are shorting your camera.
Jul 21, 2009 | Kodak EasyShare C743 Digital Camera
Calcification on swimming pool
Size the gallonage of your pool and purchase Scaletec. Double to dose. 4 to six weeks the scale will dissolve and brush off
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Calcium build up and i need to titrate my chemical
If you are asking about mineral build up in a dishwasher, add approximately 2 cups of white vinegar after the dishwasher has filled with water an begins the wash cycle. Feel free to repeat after each drain/refill cycle until you see the minerals have dissolved.
Good Luck!
May 04, 2009 | Dishwashers
Home Logo
233 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
