Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I have a kenmore side by side. Are there 2 lights in the freezer? It is dark on the bottom, are there 2 bulbs?
  • 619 Answers
Usually there is only one light in the freezer section. Make sure food is not pressed against the light fixture blocking the light.
Posted on May 16, 2010
How do you change the bottom freezer light bulb
Hello Joe;
This is Peter again. I just responded to your question. Please send me the model number.
Bottom freezers should be out-lawed. They are the highest maintenance and most difficult to service.
Nov 13, 2014 | Kenmore Refrigerators
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
How to change a bulb in the Kenmore refrigerator
Most likely, you never notice the light bulb in your freezer or refrigerator until it is not working. Then it is time to replace the bulb. This is especially important with freezers, which are often in areas with poorer lighting, like basements or garages. Fortunately, the task is a simple one.
Instructions
1 Unplug the freezer to prevent an accidental shock when you remove the light bulb.
  • 2 Open the door of the freezer, look at the top inside edge of the freezer, below the door seal and back about 1 to 2 inches from the edge. You will see a small plastic or metal panel that protects the bulb from damage and shields your eyes from the direct light of the bulb when the door is opened. Reach behind the guard and remove the bulb by twisting it to the left.
  • 3 Put your new bulb in by inserting it into the socket and twisting it to the right to screw it in. Be sure you use a freezer bulb--it is built a little tougher and is the correct wattage. You can find them at appliance or hardware stores. Plug the freezer back in to test operation of the bulb.
  • Have a nice day! : ))
    Jan 30, 2011 | Kenmore Refrigerators
    Hi. The bottom freezer light won't turn on. I checked the bulb by putting it in another appliance an it wordked. What gives?
    We have the same issue with the 22.4 Cu Ft Kenmore elite bottom freezer. Has anyone figured out the problem? Very frustrating..We have unplugged the fridge..nothing. checked to make sure it was getting power to the light socket..all good. We accidently left the freezer door open a little. maybe 15 minutes..we looked and the freezer light came on..closed the door and opened it again, the light still came on..got up the next morning and no light again..Sure dont want to spend $75.00 for a sears tech to come look at it...
    Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Side by side sub zero refrigerator: freezer is
    still not clear. in your question you say refrig side is dark and not running, then you say you put a temp guage in it overnight and it's steady. So you DO have cooling in refrig? If it's just the lights, yes it could the switch or it could be the light bulbs.
    Jul 16, 2010 | Sub-Zero Refrigerators
    Refrigerator light doesn't work
    then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
    Feb 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Sheet of ice forms on bottom of freezer
    Your defrost heater assembly has probably failed. Look at the ends of the heater for darkness like that of a bad neon bulb. Replace the heater assembly as a unit after removing the ice with a hair dryer. Becareful not to drop the glass heaters when replacing.
    Jan 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
    Kenmore Elite Refrigerator side by side
    These covers can be squeezed from the sides to release the tabs that hold it in place.
    Jun 01, 2008 | Kenmore 57029 Side by Side Refrigerator
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    82 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    dweatherby
    paulcarew
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
