Question about Kitchen Ranges
Amana Convection Electric Range won't heat above 170°F
We have an Amana Convection Self-Cleaning Electric Range that appears to have an electronic control problem. Earlier this week, when the Bake button was selected, the digital temperature indicator goes to 170° from the 350° default in a couple of seconds. Then, it only heats up to 170°, it doesn't matter how high it is set it gravitates to the 170°. I tried resetting the oven by switching the breaker off and putting it back on but that doesn't reset anything except the clock.
The electronic control is suppose to have a self-diagnostic system that displays F-codes and beeps but nothing of that sort occurred (according to the owner's manual).
The Owner's Manual does not elaborate on troubleshooting beyond a few basic checks noted under the Before Calling for Service & Common Questions. The manual also doesn't have any diagrams showing where the fuses or the control board is.
Can the above low heating problem be solved by a simple part replacement and is such an item accessible from the back of the chassis or inside the touch pad panel?
Model Number: ZRTC8500WW
Manufacturing Number: P1143445NWW
Serial Number: 9709176838
Purchased - about: August 1998 in Edmonton, Alberta, Canada
SOURCE: No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Posted on Oct 06, 2007
ngfam1
  • 639 Answers
SOURCE: I have an electric Maytag,digital
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
SOURCE: amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Posted on Nov 17, 2008
aborcass
  • 2651 Answers
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Posted on Mar 18, 2009
Oven door won unlock
I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven won't heat up
Hello Michele Smith - If neither elements do not heat but the top of the unit works, then they can possibly be faulty elements or connection. However, if you are experiencing other performance difficulties, then you may have a bad control board that needs to be replaced. Consult a professional for an accurate diagnosis.
Nov 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Replaced oven light and now oven won't work
Does the light work? Will it heat if you remove the light?
Nov 24, 2012 | Amana ACS7270AS Electric Kitchen Range
We have an Amana Easy Touch Control 500, the pilot is on but oven won't heat up. We also can't self-clean because the door won't lock or sometimes it locks and won't open. I suspect the...
Most likely the door for your kitchen range has a sensor that is not allowing it to heat up because it detects that the door is not closed.
I would suggest you consult help from a certified technician by the manufacturer of your Kitchen range that way they would also be able to check other possible faults on your kitchen range and replacement parts would be 100% compatible.
You can also check the services that these guys offer:
http://www.stoverepairnearyou.com/ml2/?v=1640662349&u=08E0B192DFA88BAA0210818080F80718DDA9032090DEAEEC8F8CA8CFC401
Hope this helps!
Jul 18, 2011 | Amana ACF4225AS Electric Kitchen Range
After putting ovens through cleaning mode, ovens are not working, no heat, ovens less than a year old, caldwellb84@yahoo.com. unit is electric not gas.
Check out this tip... You probably burnt something up besides the bad stuff in the oven....like the wiring...or a control...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Oct 18, 2010 | Electrolux 30" Self-Cleaning Freestanding...
Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Kitchen Ranges Logo
96 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
