Question about Intel Play QX3 Monocular Microscope
My QX3 worked wonderfully on my XP system, but I can't load the drivers/installation files on a Vista system.
    Problem Solver:
  • 12 Answers
Sorry, Intel stopped making these years ago. They DID post updated drivers, but long before Vista arrived. Go to the Intel web site, your only other hope is to find a blog of Intel QX3 users, maybe some gearhead updated the driver pro bono.
Posted on May 14, 2010
Testimonial: "Unfortunately, been there, done that, without success. In fact, that's where I found this site. :("
  • xernon Mar 30, 2011
    Found this softwarehttp://download.cnet.com/Intel-Play-QX3-... and ran it on win7 under compatibility mode with XP SP2. Runs good so far. hope this helps you.
    Sniper:
  • 72 Answers
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Vista.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
http://downloadcenter.intel.com /Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419& amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
Step 3. Download and extract the QX3 Drivers from:
http://tinyurl.com/IntelQX3driverXP or
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on Jul 24, 2011
Found this software http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.html and ran it on win7 under compatibility mode with XP SP2. Runs good so far. hope this helps you.
Posted on Mar 30, 2011
  • wa6qjw Mar 30, 2011
    Good idea, but too late - I sold the QX3.
    Bummer, I held on to mine and just dusted it off tonight. Tried to buy the QX5 but no one has any. Do you have a comp micro that is newer??
    Dale
Load XP on your Win 7 or Vista PC and have two operating systems.
Posted on Jul 11, 2010
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
http://tinyurl.com/QX3-Win7-Files
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
Qx3 microscope driver for Windows 8
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Apr 05, 2014 | Intel Play QX3 Monocular Microscope
Qx 3 install windows 7 64bit
Sorry, the QX3 does not work on 64-bit systems. The drivers are not compatible. There are instructions available for using the QX3 with Windows 98, Me, XP and 32-bit versions of Vista, Windows 7 and even Windows 8.
Mar 16, 2014 | Digital Blue QX5 Microscope
QX3 microscope
Dec 30, 2013 | Intel Play QX3 Monocular Microscope
Digital blue qx3 drivers
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1.
Aug 20, 2013 | Intel Play QX3 Monocular Microscope
Need drivers for intel play qx3 for windows 7 ......help!!!!
Sure, they can be downloaded easily by using this software: Driver Update Software for XP Vista 7 8. Wish you best of luck. Cheers
Dec 22, 2010 | Intel Play QX3 Monocular Microscope
Vista driver for Intel QX3 Microscope
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
I have QX3 computer microscope installed on my vista but it doesn't work
I could not find driver. I placed in Windows 98 compatibility mode on my Vista. I right click Intel Play shortcut...go to "Open File location". Find QX3 application....right click. Go to properties...Compatibility tab and choose windows 98 / Windows ME. Click ok. Worked for me hope it works for you!
Dec 16, 2008 | Intel Play QX3 Monocular Microscope
QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
Step 2. Download and install the QCODINSTL Codecs software from:
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
2,374 people viewed this question
Top Intel Science & Laboratory Experts
William McMath
Tom Chichester
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
