The screen says the cover is open - Computers & Internet
  • 31 Answers
There is a switch inside of the case that registers if the case cover is on, check to make sure it is connected and positioned correctly. You can also go into your bios setting to disable this feature and you shouldn't receive any further warnings. Hope this helps.
Posted on Mar 30, 2008
How to open the cover of 191el lcd monitor
i just open my philips 191EL monitor by lifting slowly the upper front plastic panel of the screen with a light press away from the screen. then lift going to the right side and going to the left. thats it.
Dec 14, 2011 | Philips 191EL1SB75 Monitor
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
Camera on standby open lens cover
take off the lens cover?, the cover blocking the actual camera lense, this is preventing the startup of the camera or your getting a black screen window right, or slide the cover that over the lense across
Jun 23, 2009 | Nokia N72 Cellular Phone
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
C902 can not open lens cover
You need to remover the sticker on the screen...lol
Jul 02, 2008 | Cell Phones
X20
If you open up the battery cover, you should see 6 tiny philips screws to undo, as well as two on the side of the player, opposite the headphone jack, underneath two little gray cover discs. Don't worry about opening up the player, it stays in relatively one piece besides the screws and the case. Once you undo the screws, you should be able to carefully pry open the case down the sides of the player, opening it up will expose you to the backside of the screen cover, as well as the screen itself. Just wipe it all down, and when you're satisfied, pop the cover back together, and throw those screws right back in! Pretty easy! I did have your same problem. This is what I know to do about it.
May 12, 2008 | iRiver X20 MP3 Player
How do you get the covers off? "Does not support this mode"
Well here I am again trying to get the covers off of an unfamilar device. I found the 2 screws at the bottom and removed them.. On a hp 1702 I just forced the sides open, pulling and bending to pop the cover off.. How do you get this mag cover off?
Problem indicates on screen "Does not support this mode" on power up, then screen goes blank. OSD doesnt work... blank screen... Does not support message looks good though for an instant...
Feb 16, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Records audio but no video
Replace the ccd base assumbly and check.
Jan 01, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
LCD Screen not working
the problem of your camera is the flexwire cable of the lcd monitor that why you don't see nothing in the panel,Also the message 'cover is not open' appears,while the cover is already opened the switch on cover have poor contact..it is not covered by sony service...it have to replace or repair that switch and flexwire cable....
Aug 20, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
