Question about Husqvarna Chain Saw 20" Bar
Can't start my Chain Saw Husqvarna 350.
The saw has been sittin for a year. I put new gas with the correct oil dilution and it still ,does not start. Popped the top and cleaned the spark plug..still does not start. Went to the web site and looked at the videos and did everything right. What do I do now?
The fuel may have been replaced, but is the fuel filter clean or is the fuel line cracked? Even though you cleaned the spark plug, did you check to see if it has a spark? If not, maybe a new spark plug or check the wire to make sure there is nothing blocking where the wire and spark plug connect. Is the air filter clean? Just a few more things to check out...
Posted on May 22, 2010
I just bought a used 350 husqvarna chain saw fires up n stalls right away put new premium gas in it
Start with a few simple things, replace the fuel filter in the fuel tank, check the fuel hoses for signs of leakage, replace if required.
Dec 22, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Oiler not working
remove side panel and barand chain clean saw dust out of oil port in saw and the bar as well
Feb 02, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna 350 oil not getting to chain
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
May 26, 2010 | Husqvarna Chain Saw 20" Bar
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
May 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
177 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
