What is the maximum and type of memory for a ms1 6322 motherboard
Hi if you go to www.crucial.com
look on their site and they have a programme that scans your computer and tells you everything about it and it also tells you the maximum of everything you can have like mem and hardrive i found this a brilliant site as i build my own comps to sell and having this info allows me to build the computers the the highest spec they are capable of.
Let me know if you cant find this feature or if you need further assistance ok
Hi sorry just though i was basing my help on the fact that the computer you need the info on is working and able to connect to the net if not let me know ok then i can look at another option for you to get the info you need.
ok ill have a look for you you should have waited to rate my solution till i finished helping you i said ill look into it for you but as the time differance form me to you so i could be at work when your online.
Now ive read your comment ill have a look for you ok
Hi does it have four slots
click here
this takes you to crucial.com where you can pick *********** board out of the drop down list then it will tell you everything you need to know ok.
Dont use the scan feature you can just put in manually the make of mother board and it will then tell you what you need to know ok
Let me know if this helps and if not then get back to me ok
Thanks for your reply but at the moment there is no internet access. i want to buy the correct memory module to urgrade the computer. i tried to find the motherboard on the MSI site but could not..
