Question about Panasonic CQ-VD6503U Car DVD Player
Who or where can i purchase wires for the unit
  • yadayada
    yadayada May 14, 2010
    "wires" this is a very vague request, wires for what? please be specific
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 2,226 Answers
Try pacparts.com
Posted on May 14, 2010
The new wall heater will not go on. The pilot light is on. We replaced the thermostat and the heater came on but would not go off. We checked the wiring..all good. Any advise would be appreciated.
You need to preform a continuity check between your T-stat wires. More than likely, the wire that initializes the call for heat is grounded to one of the other wires. Also, if the unit worked fine prior to the initial problem, it's likely that you haven't purchased the proper t-stat for the unit. Wall heaters typically operate using a millivolt t-stat and not your typical heating stat you would find on a central unit. If you did purchase the correct stat, then more than likely it's not wired correctly, or you have a direct short, as mentioned above, in the wiring.
As usual.....when dealing with electrical, no matter how low of current, please turn off the gas and any electrical current that the unit may have prior to servicing.
Feb 04, 2017 | Heating & Cooling
Can burned out wiring be repaired on outdoor ac unit ?
it all depends on what wiring burned up of course .but find the cause of it before trying to repair
Sep 11, 2015 | Heating & Cooling
1978 CHEVY C10 6CYL OIL PRESSURE SENDING UNIT WIRING
Take the sending unit back, either you truly have high oil pressure and you blow the oil filter or the sending unit is shorting together with power,or the harness has rub through together, either way get another part under warranty and go from there,and be careful how you install the unit
Nov 09, 2012 | Cars & Trucks
I have this model of Head units. I have used crimp connects to connect the unit harness to the car harness. Hooked up my turn on wires and rca cables. Now my head unit when turned on shorts in and out and...
For starters, I want to make sure. You did purchase a wiring harness that "plugs" into your vehicle, right? If not and you are attempting to hardwire to your vehicle, STOP! You run the risk of frying your entire electrical system. If you purchased a harness you can crip the wires from your head unit to the harness and the harness plugs in. DO NOT crip wires directly. You are experiencing just a little of what can happen. However, if you did purchase the correct harness, you need to check all our crimps again. Hope this helps.
Aug 21, 2011 | Car Audio & Video
I have a XOD1760BD double Din DVD player. I am in need of the wire harness that plugs into the radio itself. I have a new unit but no wire harness for it.
If this is a new unit and didn't come with the harness, I would contact the company or retailer you purchased it from. If you purchased it from an individual, you may be screwed. Companies rarely sell those specific parts due to the possibility that the unit is stolen. You will probably need a dealer to order the part if it is available. Hope this helps.
Aug 18, 2011 | XO Vision Car Audio & Video
I purchased a nutone ls100 to replace my se80 but the wiring is different. The 100 has 5 wires and the 80 has 3 wires.
Is the LS 100 you purchased complete or motor only? i would buy it from you if it is the complete unit. 907-232-2142, thanks
May 06, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
HAD Carrier Digital unit, did not like, purchased Hunter, which I could not get to work Now I have extra colored wires hanging from the wall that came off the carrier that I did not tag.
Put the carrier unit back on the wall and connect the colored wires to the designated terminals.
R-Red, G-green(fan), Y- yellow and so on until they are all reconnected.
Manufacturers controls are designed to operate their units and sometime have more control options that require the extra wire you experienced with the off brand unit you purchased. Take it back and get the instruction manual out for the Carrier unit and learn to like it. If you have aZone System it is the only cotrol that will work with your system.
Oct 23, 2009 | Heating & Cooling
'Yellow Wire - Stereo Connection???'
Yellow wire connects to the music mute wire on the back of the car stereo (usually brown). This will mute the stereo when the hands free is in use!
May 28, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
Panasonic CQ-VD6503U Car DVD Player Logo
29 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
