Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Circuit Braker Jumps Off
Could you help me troubleshoot why a Jenn-Air 30 in CCe3401B circuit braker jumps off?. It has been working just fine for 7 years. Any ideas where to start? Thanks.
Pete
    Novelist:
  • 161 Answers
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Posted on Jul 01, 2008
I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
Dec 31, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
GE jgp328 front ignitors won't turn off. How do I remedy this?
Did you just clean it? If the swiches under the burner knobs get wet, they cause the electrodes to click. Unplug the unit or turn off the braker for a day. it should dry up and work normal.
May 04, 2009 | GE 30 in. JGP328 Gas Cooktop
Poping sound, sparks shooting out and 220 circuit breaker out
Did you move the breaker fully off before turning it back on? make sure the offending burner is off.
It sounds as though the element shorted out.
Mar 17, 2009 | Jenn-Air JED8430 Electric Cooktop
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430BDB blowing fuse following ceiling fan work ...OUTside!
You have posted this to a public webpage that has 7 million visitors and is nothing to do with your electrician 'Eddie'. You have also posted your telephone number and email address to those 7 million viewers.
Feb 27, 2017 | Jenn-Air 35 in. JEC9536 Electric Cooktop
F7 Error
This error happens if a function (key) is stuck. Usually the one that is used most often or the one that someone poked using something pointed.
Change the touch pad if it is separate from the clock (ERC or EOC) or change the whole clock if they are one unit
May 05, 2008 | Jenn-Air JED8430 Electric Cooktop
Circuit Braker Jump Off Easily on GE JP350 Cooktop
The ciruit breaker might not be of sufficient rating. Tell us what is the number written on the breaker?
Oct 27, 2007 | Cooktops
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
137 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
