Opc and leave come up occassionally on the bottom of my tv screen
  • 4,889 Answers
Please let me know the make and model of your tv so that I can help you with your problem.
Sai.
Posted on May 14, 2010
  • 1 more comment
  • cterry401 May 14, 2010
    sorry lc-32sb23u opc lights up at bottom of screen frequently with pictures of tree leafs.
    lc-32sb23u opc light up at bottom of screen with picture of leafs. how do i get it off
  • eagle338
    eagle338 May 14, 2010
    The message you are seeing is due to the OPC indicator being on. Please refer to page 18 of the manual below for instructions on disabling it The manual is compatible with 3 different LC32 series models including yours(I have cross checked to be sure)
    http://static.compusa.com/pdf/Sharp_LC-3...
How can I get the TV screen to come on when only the power and OPC lights flash?
Even when the TV is off, some electronic components in your TV consumes power 24 hours a day. Maybe a power surge damaged your TV when the power came back on.
Aug 02, 2014 | Sharp LC-32SB24U 32 in. LCD TV
Is it normal for opc and the green leaves to flash across my screen on my sharp tv?
You can turn this feature of in you menu. It is adjusting to change in roomlighting when you see this come on. Look in your menu for OPC on off setting under features menu.
Jul 09, 2011 | Sharp LC46SB54U 46 in. LCD TV
My opc led burns when i turn on the tv
You can leave it on and enjoy the tv self adjustment feature or turn it off by pressing menu. Navigating down to opc and pressing enter. Navigating to off. Pressing enter and then pressing menu.
Mar 15, 2011 | Sharp Televison & Video
TV will not turn on. There are two lights in front at the bottom of the screen - One is the power light, one is the OPC light. When the power cord is plugged in, both lights flash twice, then the OPC light...
Sounds like your screen is broken or has been impacted. Force the television on by doing this: Unplug it and on the side of the television where the panel buttons are hold down the ch- and vol+ buttons. Then plug in the television while still holding them down. The television should come on and you see the cracks. Unfortunately it can't be repaired.
If it isn't ch- and vol + then try ch + and vol -.
Feb 05, 2011 | Sharp LC46SB54U 46 in. LCD TV
What does opc: mean at the bottom of the screen?
OPC means Open Packaging Conventions on a sharp Aquos TV. The Open Packaging Conventions (OPC) is a container-file technology initially created by Microsoft to store a combination of XML and non-XML files.
Nov 16, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What is opc that pops up about every 10 Min
OPC is optical picture control. The television is adjusting itself to the lighting in the room. Even if someone walks in front of the television's sensor it will start to adjust and you will see opc on the screen and green leaves.
You can leave the feature on without the opc and green leaves appearing on the screen. Press the menu button. Scroll down to OPC. Press enter. Scroll to on. Press enter. Press menu to exit.
Sep 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Image
I have the same problem with my TV. Apparently it is a problem with the backlight inverter board. The only thing that has consistently worked for me is to switch the OPC setting to on (display). Get a small piece of electrical tape and when you turn the tv on wait for the OPC 'leaves' bar to load a bit and then cover the OPC light sensor at the front of the tv. (it is the one right beside the power light). Hope this works as well for you as it did for me. Good luck
Dec 16, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp D64 37" issue (Power+OPC light flash and won't turn on)
I'm going to guess your friend's model is LC-37D64U. ( 37" screen; D64 series)
It's sounding like a power supply problem for the LCD screen. It's somewhat common problem for big LCD screens. But, too early for your friend to be having this problem with the TV.
I would have your friend use the warranty at this point. Last thing you want to do is void the warranty by opening up the TV.
I would first try leaving the TV unplugged for 30 mins so it can reset. Then, try turning it ON again.
If that doesn't work, it warranty time.
If your friend just bought it, have them exchange the TV for another one. I wouldn't want a TV that has problems that just came out of the box. The Sharp TV only has a 1 year warranty. Upgrade warranty life if possible. A repair for a problem like this would cost about $100 for someone to look at it; and $200 to $400 for the part at a TV repair shop.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
What is OPC flashers on screen sometimes
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
Jan 04, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
