Question about GE Dryers
I have a 2 year old dryer - dhdvh66; not heating, and intermittently makes a buzzing noise on the back side as it tumbles. what do you think?
  • 76 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
Posted on Feb 26, 2007
  • 172 Answers
SOURCE: How do you replace the
Hello Jkahle9,
You are in for a big job there. I will try to give you the best step by step possible. First get you a rear bearing part number 131825900. This part retails for $5.96 but you may pay as much as $11.99 This is only for the bearing not the ball that goes on the back of the tub. You will also need some white lithium grease. You will put a small about inside the rear bearing.You may also want to have a second person to help screw the bearing in place.
Step one will be to unplug the machine and pull it out so you will have access to the back. Most of the repair will be done from the front of the machine.
step 2, You will need to pop up the top of the machine. You do this by inserting a flat blade screwdriver into the two clips holding the top down. They are located about two inches from the left and right side front under the top.
Then you will need to remove the front panel and door. You will do this by removing the two screws from the top left and right of the inside of the front panel. the front will then tilt forward from the top and lift off. Use caution because your door swith will still have two wires attached. You can leave these inplace.
next will be to remove the belt from around the tub. To do this reach underneath the tub and remove the belt from the idler pulley and the motor shaft. Remember how you take this off because you will be putting it back shortly. When the belt is loose you will use it to lift the tub upward with a sharp ****. The rear of the tub has a ball and socket joint and the ball must be pulled up and out of the bearing. When the rear of the tub lifts up you will then remove the tub out the front exposing the rear bearing and the heating element. Note, If you damage the heating element while doing this you will need to head back out to the appliance store and buy a new one. You can not take extra slack out of the heater if you have stretched it.
The final step will be replacing the bearing. Use caution so you do not loose the small ball bearing in the rear center of the bearing. You will have two screw to remove and a small metal bracket on the back of the machine. When reinstalling the screws you may need that second person to hold this bracket. Once installed and the small ball bearing is inplace add the grease. Look at the ball on the back of the tub to make sure it is not bad. If it looks ok then just reassemle and start drying. Good luck. MCA0824@aol.com
Posted on Apr 30, 2008
futureloginn
  • 734 Answers
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint vtd00p tumble dryer giving
I assume you fitted the right value capacitor and connected it up correctly,if you have then slip the belt of the motor, and make sure it is free to turn with no resistance.
Try it without the belt on, if it runs o/k then problem is elsewhere, if it still does not run , then you could have faulty motor, and or timer. That is as much as I can help you.
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
SOURCE: My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Posted on Apr 11, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
I have a tumble dryer bush tdv6b got from a friend not very old was working fine now its not doing anything apart from a slight buzzing noise tried the reset at the back does nothing thanks
MOST PROBABLY THE CAPACITOR BESIDE THE MOTOR NEEDS REPLACED. http://www.buyspares.co.uk/tumble-dryer/tdv6w/capacitor/product.pl?pid=4058219&shop=bush&path=864668&refine=capacitor&model_ref=8702213
Jan 31, 2016 | Dryers
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My Whirlpool Cabrio just started making a clicking noise. It's only a year old. Any ideas?
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Jun 27, 2011 | Whirlpool WED9200SQ Electric Dryer
Fisher & Paykel DEIX2 (electric) dryer -- squeaking The F&P (4 years old) has a squaking that occurs when the drum is rotating. It was intermittent and is now continuous. I'm handy, but I'm...
drum roller/glides, idler arm, belt,or motor:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 27, 2011 | Dryers
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Beko tumble dryer was making strange noise now no heat but still spinning
How old is your dryer? strage noise usually take place if the unit is old and worn out. I dont know of any washer or dryer doesn't make noise after years of using. The more you use the more ware and tear and noise come from the unit. Noise can be the belt loose or tumbler padding or flange, connected to a simple bushing is worn out, making the unit woobily noisy. No heat mean your heating elements probably burnt out need replacing which will cost 80-100 bucks. its fairly easy to replace once you remove the back cover. To find out what making that noise, the best thing to do is run the dryer with the back cover off by look and listhen and see what making that noise.
Jul 08, 2009 | Dryers
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Dryers Logo
80 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
