Question about LG Xenon GR500 Cell Phone
How do you do a master reset touch screen is not working
  • 343 Answers
Perform a Master Reset
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Reset Setting.
  4. Scroll to and select Reset Defaulhow do you do a master reset - pattlnk_752006_1630-reset1.jpg.fixya.net/uploads/images/pattlnk_752006_1630-reset1.jpg" alt="pattlnk_752006_1630-reset1.jpg" class="h_mi" />
  5. Enter Security codhow do you do a master reset - pattlnk_752006_1631-reset3.jpg: The default security code is 0000.
    4. Scroll to and select Clear Memory.
      pattlnk_752006_1632-reset_mem.jpgScroll to and select desired option:
      • Handset Contents
      • Handset Personal info.
    5. Scroll to and select Yes.
    6. Enter Security code, press OK.
      NOTE: The default security code is 0000.
Posted on May 14, 2010
2 Suggested Answers
SOURCE: touch screen not working at all
i use a w910i and it does not have a touch screen ,are you sure you have the correct model number
Posted on Apr 10, 2009
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
Jun 29, 2014 | Motorola Cell Phones
M600 screen
I'll assume that you shut down and restarted the phone. Did you try taking the battery out. If that doesn't work, a master reset might. You will lose data, so the master reset is a last resort. Which is what anyone you take the phone to probably will do. There are known issues with the touch screen on the M600's and they can be replaced. You can find replacement touchscreens with the tools needed on ebay.
Apr 13, 2014 | Nokia Cell Phones
Touch screen not working
hey indik, u can just perform master reset on your phone will might help u out.
May 09, 2013 | ZTE Score
My Garmin nuvi 205W was working fine but I wanted to update it on the computer before a family trip. Update seemed to work fine but the unit would not turn back on afterwards - not in the car, by USB, or...
Have you tried a master reset??
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Nov 24, 2009 | Garmin nuvi 205W GPS Receiver
Dead battery garmin 755t.will not turn on even when hooked to charger
try holding the power button to the on position until it turns on (give it up till 1 minute to turn on) if that does not work, try a master reset, but be aware A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
To do a Master Reset on the nuvi® 2xx, 2x5, 5xx, 6xx, or 7xx:
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nüvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Jul 14, 2009 | GPS
Touch Screen Isn't Working
We had the same problem, but was able to call tech support at AT&T. The solution we were given was to do a Master Reset of the AT&T Tilt-Phone.
But before we did the Master Reset, we used the synchronize software to do a full backup of data and photos.
After that, we had to go through the setup process and of course the screen setup as well (which did work).
Bob
May 10, 2009 | AT&T 8925 Tilt Smartphone
Display reads no detailed maps found that support routing.
Try a Master Reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 2xx series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. But who cares if you have problems, right?
  6. Touch Yes
Jan 29, 2009 | Garmin n?vi 260W GPS
LG Xenon GR500 Cell Phone Logo
649 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
